Results 1 to 10 of 10
Thread: About to cut my dash - advice required
    Newbie meep's Avatar
    Jul 2009
    Hi Knowledgable People
    I'm installing an 8" lilliput in my HiLux (see blog) and need to cut a section out from my center console fascia, (the crossbar in the picture below).
    I've no idea what the material is (certainly not wood!!) and I want to make the cleanest cut possible. Any advice on tools or techniques? Should heat be involved?
    Thanks in advance
    Peter
    Dec 2006
    BK, NY
    if its not pvc plastic then some composite. You won't be able cut the excess piece and have a clean looking part without doing some molding/shaping/sanding/painting. If you do just want to cut it off, the cleanest cut you can probably get with a dremel and a steady hand.
    good luck!
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    had the same stuff in my altima years back. You can use a dremel with a cutoff wheel... but be very careful to cut right at the thinnest part of the joint to avoid having to sand too much away and ruining the angles.
    Live mp3Car Facebook Chat
    VENDOR - Nexations Creations Nexson's Avatar
    May 2007
    I hate to be non-optimistic here, but I just see no way of cutting that woodgrain bezel and making it look clean after it is cut. Even I can't cut a 100% straight line. I have a really good steady hand with my dremel, but even after a cut, you will have little jagged ends that need to be sanded down. Anyways even if you don't sand them down, the inner cut edge will be white and not wood grain.
    This is a tough one. I suggest molding it in and ditching the wood grain. Or paying some decent $, and mold it in and get it re-wood grained.
    It is your choiuce, it depends on how anal you are.
    Brian @Nexations Creations
    Specialist in Custom Interior Fiberglass OEM Replication Work.
    AIM: Exus28
    E-Mail: Exus28@aol.com
    Constant Bitrate MindDrive's Avatar
    Feb 2008
    Shorewood IL
    ^^^^^^^ if Nexson says "dont do it" then i really would listen to what he says.... look at his portfolio... its sick the way he makes oem projects look well... oem LOL
    Props to ya Nexson for lookin out for this guy
    May 2007
    Quote Originally Posted by MindDrive View Post
    Thank you!! I really value your kind words!!! I figure it is the least I can do to help out
    AIM: Exus28
    Jul 2009
    Many thanks for the feedback everyone. I'm not too concerned about it being 100% oem, I'm happy to live with some rough edges - it's a work vehicle after all.
    Mar 2009
    near Rochester, NY
    I doubt that crossbar is solid, so you might have holes where the ends were once you cut it out.
    Jul 2009
    Oh, I know I will.
    Here's a pic from a guy who's done something similar in the same type of vehicle:
    I'm going to have to think about how I deal with that.
    Peter
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    Quote Originally Posted by meep View Post
    Oh, I know I will.
    Peter
    If you're willing to give up all of the woodgrain, you'd have the same issues he did. But there may be a way around that.
    If you'd be willing to give up some of the woodgrain, you could make your modifications to get the parts smooth, keeping your work in a narrow area. Then choose a comfortable line around that area, and paint the edges you worked on. For instance, you might leave the face woodgrain, but bring the inner area to the dash color. You might even be able to scribe a narrow line between the two; if you could put a very dark gray or flat black paint (or ink, or tape) into that line, it would be a good visual demarcation.
    Nexson can guide you on that. His version of OEM is often better than OEM.
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
  1. Help me fab my dash, Nexson come plz
    By TexasAggie in forum Fabrication
    Last Post: 07-23-2009, 03:19 AM
  2. Replies: 3
    Last Post: 03-16-2007, 12:49 AM
  3. Fs: Custom Escalade Dash & Carputer!!
    By EsKALad in forum Classified Archive
    Last Post: 11-09-2006, 11:24 PM
  4. Fiberglassing over a vinyl dash
    By tml240 in forum Fabrication
    Last Post: 08-30-2006, 01:19 AM
  5. 2002 Silverado Custom Dash Bezel
    By AZ_Silverado in forum Fabrication
    Last Post: 08-09-2006, 02:46 PM
