Results 1 to 6 of 6
Thread: Redoing vinyl on door panels (E36)
    Nov 2006
    So I'm looking to redo my dove grey door panels in black pleather, but I'm not sure what material to use or how to wrap it really. I think the panels will be easy, but I'm interested in learning how to large pieces with curves (dash, center console). Do I need to use a heat gun? I was wondering if there was a guide on this anywhere...just like general tips.
    My door panel looks like this except, gray:
    Any pointers would be appreciated. Thanks.
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    Try and look for "vinyl upholstery tutorial" or "vinyl upholstery instructions".
    One thing you might consider is spray coloring for vinyl. Instead of re-wrapping it, how about "painting" it?
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
    thekl0wn's Avatar
    Apr 2005
    PoCo, Indiana
    I've seen good and bad results from the vinyl dye. As with everything else, it's all in the prep work.
    Play with it, 'til it's broke.
    Nov 2006
    I've looked into SEM and VHT, and I think I'll pass on those due to the durability issues.
    Also, I want to cover my dash which is a hard plastic, and apparently neither of those two products leave a permanent finish.
    Do they sell the vinyl at a place like Joann?
    Apr 2007
    Atlanta, GA, USA
    Quote Originally Posted by addnon View Post
    Yes, I've gotten vinyl there, and they had several thicknesses of the foam padding you'll want to use.
    May 2006
    Calgary, Alberta
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
  1. Vinyl trimming
    By mk1fan in forum Fabrication
    Last Post: 10-20-2006, 07:09 PM
  2. Fiberglassing over a vinyl dash
    By tml240 in forum Fabrication
    Last Post: 08-30-2006, 01:19 AM
  3. Vinyl information
    By brentm in forum Fabrication
    Last Post: 04-15-2006, 03:43 AM
  4. 99 Honda Prelude Carputer wrapped in Vinyl!
    By SuperDave01 in forum Show off your project
    Last Post: 10-10-2004, 03:19 AM
