Results 1 to 4 of 4
Thread: Bondo Glazing & Spot Putty. What can I do with it.
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    I had to repair a hole in a arm rest panel I made. I didnt know what to buy, so I bought Bondo Glazing Putty and I filled in the hole, and the paint to match the arm rest. I think I did a very good job, it was easy to use and hardens very strong. I was wondering if I can use this for large applications, like filling a long hole. Also can I use this to make a shape? Anyways, give me feed back on what to do. Here is a pic, its my first time, so be nice.
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
    Maximum Bitrate bratnetwork's Avatar
    Oct 2007
    Haledon, NJ
    glazing putty is basically just really thick paint. it is not meant for filling, shaping or such things. its purpose is really just to fill in sanding scratches and leave a smooth surface to paint over. I don't think it has the strength to hold up over time as a filler or shape.
    Dec 2008
    dynatron 660, as mentioned here a lot, is by far the most amazing epoxy i have ever used. you can literally make plastic parts out of the stuff, and they will be stronger then any of the plastic in your car. its also some of the strongest adhesive ive used. i would bet dynatron could even repair broken side mirrors... where the plastic mounts just snap off.
    Jul 2007
    Miami
    Quote Originally Posted by trader007 View Post
    But do you have to mix it like bondo? What I like about this tube is that its already made, just squeeze out the tube.
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
  1. Replies: 28
    Last Post: 09-04-2007, 11:10 PM
  2. What is Bondo..
    By ryan-neil in forum Fabrication
    Last Post: 04-07-2006, 06:22 AM
  3. Bondo Applicatin Question
    By jmciver in forum Fabrication
    Last Post: 02-16-2006, 07:58 AM
  4. used too little hardener for the bondo
    By fullgrown in forum Fabrication
    Last Post: 08-01-2005, 03:37 PM
  5. Very Unique Bondo Problem! Paint Screwing it up?
    By Grayscale in forum Fabrication
    Last Post: 01-09-2005, 12:34 PM
