Page 10 of 38 FirstFirst 1234567891011121314151617181920 ... LastLast
Results 91 to 100 of 376
Thread: Need ideas on how to accomplish getting a screen fabbed into my bezel please..
  1. #91
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    Quote Originally Posted by tbird2340 View Post
    Cool, then that's the one I'll get..
    Now I just need to decide if I should try using EWF & HORM.. Does using these limit the functionality of Windows at all? You install EWF on a CF card for faster booting, right? I know the case I'm getting comes with a CF reader which is nice..
    nst6563 tells me that EWF makes his systems boot faster. I haven't tested that myself. EWF is pretty much a necessity on a CF card system because there are a finite number of times you can write to one of those cards. Not to mention much like an SSD writes is slower than reads. EWF with HORM isn't that much different than using hibernation, other than you always start from the exact same hibernation every single time, no shutdown required. nst6563 was getting like 12 second resumes with his system. I think he gets sub 15 second cold boots with just EWF. Hopefully he'll notice that I keep mentioning his user name and will pop in to give his 2 cents.
  2. #92
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Yea, I agree... So I will be getting that board, IF you can answer this for me..
    This is only going to be doing video (xvid avi's), GPS (Iguidance), and music.. For the most part, that's all it will do.. Will a single core Atom CPU have enough balls?
    I had an EPIA M10000 a LONG time ago and that thing was slower then shiite! It also had a slow laptop HDD so that was probably part of it.. Anywho, just wondering if this will be speedy enough...
    I honestly do not know. I too started out with the $h!++y VIA M10000 and it was slower then slow. Alot of people say dual core is overkill, but i see people putting more and more complicated things into the car, so they need that power. If you honestly think you will be using the system for light use or casual use, then it may be ok. For major use, Id go with dual core.
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
  3. #93
    Jul 2007
    Miami
    Quote Originally Posted by Machinehead View Post
    I heard boot up is a bit faster also. The main reason for using it is like Machinehead said, you do not write to the drive. There are a few benefits to this. One it saves the life of the drive. Two it writes everything to RAM, so say for example your on the internet and some b!+ch infects you PC with a virus, a simple reset will kill it. Also there are no corruptions.
    Bad thing is, when installing new programs, you have to remember to turn EWF off or it will write to RAM and not be there the next time you power on. Kimota solved this by having icons on the desktop to turn EWF on and off when need be. HORM is basically hibernation, but more extreme. The PC will always hibernate from the last exact time you hibernated. So even if you did 500 tasks, once you power on, it will go to the first hibernation ever.
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
  4. #94
    Jun 2007
    Quote Originally Posted by HiJackZX1 View Post
    I did that exact same thing. Much easier than remembering the command line for that function.
  5. #95
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    So I'm assuming you guys both use this currently in your CarPC setups? How do you like it? Better than the standard windows install?
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
  6. #96
    Jun 2007
    Well, I can't do hibernate in XP with my set up due to hardware issues, so I'm not using either at the moment. nst6563 is running strictly EWF, and I will be doing the same as soon as I have a free weekend to re-load my rig.
  7. #97
    Jul 2007
    Miami
    No, I plan on using it on the six PC units for the passengers, but the Main PC uses standard Windows. The problem is that when you use EWF you have to have enough RAM for it to work OK. They recommend at least 1 gig for EWF, and then you need at least 1 gig for the system to run good. Thats why I am using it on those units, they do not need to be super fast, so 2 gigs is good enough.
    My main PC on the other hand has to be able to use all 4 gigs of RAM. It is doing way to many things graphically, and my GPU uses that RAM. I also run emulators, like Viva Nanno, PSXE, and Dreamcast and what not. All my components, just way to much stuff. What I do plan to do with the main system is make it stable, then make a perfect image of the HDD. If it dies i'll buy a new HDD and copy the image onto it.
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
  8. #98
    Jun 2007
    Evey time Hijack starting talking about the 7 PCs he's going to have in his SUV I just shake my head. It's extreme to the extreme, yet extremely cool. I really should start reading your work log.
  9. #99
    Oct 2003
    Poland, OH
    No kidding.. It's the most involved installed I have ever seen.. Absolutely INSANE!!!
    There should be a "Top Installs" thread because he would be one of them fo sho!!
    SIDE NOTE: I just ordered the Zotac! Giddyup!
  10. #100
    Jul 2007
    Miami
    LOL, well my whole point for doing it is to show that it can be done and its worth doing. I just want all passengers to enjoy their time in my car. My main point was to show that a car like a Dodge can out do any luxury car if the owner puts their mind to it.
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
  1. Playing full screen video only to rear screen
    By yossisibi in forum Centrafuse
    Last Post: 10-29-2006, 07:06 AM
  2. Some Ideas needed for screen fab.
    By Aisdale in forum Fabrication
    Last Post: 09-18-2006, 03:25 PM
  3. Wanted Screen bezel for 01-05 civic
    By jdisenberg in forum Classified Archive
    Last Post: 02-09-2006, 01:21 PM
  4. Replies: 1
    Last Post: 05-01-2005, 01:25 AM
  5. Screen Bezel tips for corners of the screen
    By Gavc in forum Fabrication
    Last Post: 04-10-2005, 06:03 AM
