This is the type of rocker I would want but I think it may be too deep for that location (not even sure if it's the correct type).
Stupid question...
What are the technical terms for the types of switches / buttons I need?
I want one that is a hard on / off switch and I want one that is a push button (reset).. I'm on mouser.com and they have over 1,000 but I want to narrow it down to the correct type I need (ie: SPDT, SPST, etc).
Thanks!
Current Vehicle: 2007 Dodge Nitro
Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
First Vehicle: 2003 Ford Ranger
I hate that mouser site, I can never find what I'm looking for there.
Got my solid state drive today.. Here are some boot times:
Cold boot Windows XP until Centrafuse is running - 44 seconds
Cold boot Windows XP with Minlogon until Centrafuse is running - 38 seconds
Cold boot Windows XP with Minlogon and EWF enabled until Centrafuse is running - 33 seconds
Not too bad times..
One thing I'm having problems with though is figuring out how to disable EWF so I can make changes to the system and then enable it again after I make those changes.. I think someone on this thread said they had bad files to do so.. If so, could you post the code please?
Thanks!!
It's easier just to create your own. Open notepad. Copy and paste the text out of the GranTuring blog, or from right below. Save the file. Rename the text file and change the extension to .bat. Make one for each command. Done.
ewfmgr c: -commitanddisable –live
- This will immediately disable EWF and commit all changes to the volume.
ewfmgr c: -enable
- This will enable EWF on the next boot up.
Yea, I tried using those but for whatever reason it wasn't working.. Maybe I'm doing the process wrong..
So do I run the commit... bat file, then make any changes I need to make (install programs etc), and then run the enable bat file? Is that the order it should go in?
This don't look right.. For whatever reason it's putting a funky character for the "-" before the "live". When I run it via command line it works.
I re-edited my bat files and deleted the "-live" and retyped it and now it works.. Weird!
Well the hits just keep on coming.. Just found out the Zotac board's DVI port is digital only just like the Intel board I was going to get but decided not to because of that exact reason..
That means I can't use the DVI to VGA adapter that is commonly used and that I am SCREWED!!!
You can put a shortcut on your desktop to turn on and off EWF. I am not sure how to do it. I know Kimota does, and Machinehead probably does too.
Basically all these new mobos that are coming out are all DVI-D. Reason being is thats what most people have on their LCD/HDTVs. I see alot of people use these as media center units, so of course it makes sense to make it a DVD-D. It could also be its cheaper to make it pure digital then to make it digital and analog.
HiJackZX1 w/ The Tobiathin Core PC system!
ZOTAC GF9300-G-E
INTEL E8200
4 Gigs
OCZ Vertex 2 SSD
OPUS 320
1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
Starting Raspberry Pi multizone project.
