Your going to have to take the console out and run the wire. Trust me its much easier to run from the dash to the console, then from the dash to the rear. Thats my opinion, but the rear locations look good also. If you want to run the wires to the back, it will require more panels to be removed then put back. I know its a b!+ch because I had to take out all my interior to do what I wanted.
Of course though, you will not have alot of cables like me.
I think you should have the screen in dash, with maybe a few components. Then the console can hold the PSU and MoBo, then under the seat, the AMP.
Something like this: http://www.bluenook.com/product_detail.asp?pid=1635 for the adapter. I am starting to think though that the best thing to do is buy a M2-ATX and power it off the 12V rail. Only reason I say is because alot of car adapters put out 15V, which I am not sure the MoBo can handle. In my setup I plan to use two M4-ATX to power all 6 boards. Let me do more research on the MoBo and see if it is ok to take in 15V.
LinkBack URL
About LinkBacks
