Results 1 to 10 of 19
Thread: mdf or plywood pc case?
    Jan 2009
    i will redo my pc case in wood ..
    so what type of material is better for carpc?
    plywood or mdf?
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    MDF is denser than plywood. If you use screws with MDF there's a finite number of times you can remove and reinstall them. If you work with MDF make sure you use a dust mask, you don't want to breath in that crap.
    It doesn't really matter though, either should work fine.
    Jan 2009
    mdf is denser but..
    is it more rigid than plywood?
    and wich is better for humidity and moisiture?
    Jun 2007
    Depends on the thickness. I don't know first hand, but I don't think you can get MDF as thin as plywood.
    Jan 2009
    ok so plywood would be more rigid than mdf in a 3/8 thick case
    ha...and i'm concerning about sound level in the case...so looking for a good compromise between the two
    thanks for your help
    Jun 2007
    I just checked you can get MDF as thin as 1/4". As far as sound level, the denser MDF will deaden the sound more than plywood.
    Jan 2009
    tthanks
    Jan 2009
    maybe a could put aluminium tape in the casing for interference...and cooling
    Variable Bitrate djvillar's Avatar
    Sep 2006
    New York, New York
    The "R" value of MDF is pretty high, so keeping it cool wouldn't be a problem with a small fan pulling air in and push air out [or just a clear aperture to let hot air out]. Also do a Google search for T Nut. You can use these to mount the board so as to be able to mount, unmount, and remount multiple times. You can get these at Homedepot or Lowes. I couldn't find them on they're websites but I know their stores carry them.
    Jan 2009
    Quote Originally Posted by djvillar View Post
    thanks very helpful
