Page 3 of 8 FirstFirst 12345678 LastLast
Results 21 to 30 of 79
Thread: factory finish iphone mount fabbed into dash - 97 4runner
  1. #21
    VENDOR - Nexations Creations Nexson's Avatar
    May 2007
    Tape your phone up really well, then just the body filler along all the sides. You will get much nicer lines aroundyour phone. Epoxy putty is great for structure, but you have to use the body filler to tweak the fine lines
    Brian @Nexations Creations
    Specialist in Custom Interior Fiberglass OEM Replication Work.
    AIM: Exus28
    E-Mail: [email protected]
  2. #22
    Nov 2009
    Quote Originally Posted by Nexson View Post
    Awesome advice, I did tape up and epoxy puttied around it, but it was difficult to get even lines around it, I will definitely tape it up again and shape the filler around it.
    All the great advice has pushed me to start the refinish process tomorrow!
    I shall post progress!
    Thx again!
  3. #23
    May 2007
    Yea, Pop pictures up where you might have questions. I am always on here, so you will get answers pretty quick
    AIM: Exus28
  4. #24
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    Take the time to repair the area where the connector goes in, and get that straight. If that's what everything hinges on, fix it. Carve away the epoxy that's in the wrong place. It's worth it.
    Then do the epoxy again and apply all the knowledge you've gained. Fill, sand, fill, sand . . . make it so Nexson is impressed. You can do that.
    It'll take more time, but you'll love the result.
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
  5. #25
    Variable Bitrate djvillar's Avatar
    Sep 2006
    New York, New York
    If your going to redo this project I'd get a ipod hard case and mold up to it.
    Forget taping up your ipod and then prying it out later. Just get something which is already a finished product that is intend ed to do exactly what you need,.. slip you ipod in and out.
    This way you can line in up, glue in place and start filling it up. The edges will be perfect because its pre-manufactured
    maybe something like this, just cut the top .5" off:
  6. #26
    May 2007
    ^ That is a great idea.
    As long as it comes out freely, that is going to be a great option.
    AIM: Exus28
  7. #27
    Nov 2009
    Thumbs up
    Quote Originally Posted by djvillar View Post
    Definitely a great idea to get the best lines, though I'm definitely done with re constructing this dash bezel.
    rather than cuting up and completely starting over, I will simply be practicing my finishing by getting the finish as perfect as I can get it...
    Then in July 2010, when the new iphone comes out (want to wait to see weather they change the shape and/or connector) when I will buy a new bezel from a scrap yard (this one is beat up enough it makes more sense to start fresh with less cuts) and with everything I've learned from this one make a new mold...
    - using a hard case as you've suggested by cutting and attaching the doc (basically extending the doc) and cut of the top half inch
    - epoxy it in straight this time :P
    - place it centered with the entire bezel (more to the right towards the remaining vent)
    - possibly fab in a Lilliput 7" touch in the double din and move the stereo single din head unit to where the car charge and ashtray is now
    The 7" touch will only happen if there becomes some way to get touch screen input form the device to the iphone by then, so I can really make this sucker as CAR PC like as possible
    I really want what Bugbyte was going for before he diverted towards teh whole cloud computing angle. I'm getting there with the fabed mount, ODBII, bluetooth ipod controls I will be mounting onto steering wheel
  8. #28
    Nov 2009
    Ding Ding Ding... Round two has begun!
    ok so here we go, about to start round two. Here she is sanded down to primer and ready to get some filler to...
    - smoothen out the transition form putty to plastic
    - straighten out the bottom line under the iphone dock
    - get a nice clean even lip all around the iPhone
    (I will mask iPhone, spread filler around edges, let dry and pull out masked iPhone)
    I will take my time with the finishing this time as sanding down the primer was more painful then most of the freaken finishing process itself!
  9. #29
    May 2007
    good luck! I am here for support when you need me
    AIM: Exus28
  10. #30
    Nov 2009
    2 part Bondo body filler (yes this is my first time ever using the stuff and I made a mess )
    - but i think it should be ok, since i will just have to sand a bit more since it's gobbed on too think, and i will...
    - add more filler on the bottom line if needed to straighten (a little build up on left side maybe)
    - add more filler around the edges of the iphone mold, when the iphone is taped and in place
    ? for the gurus, I was thinking of using saran wrap on the iphone instead of masking tape so I can see the silver outline on the front of the iphone to make it much easier to shape around it cleanly and even!
    - I'm nervous about saran wrap, will it protect my $800 CAD iphone enough?
  1. 2000 Civic. Custom Dash. Factory Finish
    By pcmofo in forum Show off your project
    Last Post: 01-29-2009, 06:14 AM
  2. Dash mount screen in GM Chevy Tahoe
    By slushieken in forum LCD/Display
    Last Post: 06-19-2006, 03:31 PM
  3. 2000 Toyota 4Runner 10.4 inch lcd dash mount almost done
    By eacarrender in forum Show off your project
    Last Post: 05-11-2006, 11:42 AM
  4. Just bought a "project" dash.. pda mount suggestions?
    By CA 3000GT in forum Fabrication
    Last Post: 06-01-2005, 12:28 AM
