Results 1 to 10 of 16
Thread: Is this acceptable? (Fiberglassing question)
    Jul 2009
    Question Is this acceptable? (Fiberglassing question)
    Alright so I'm about to start making the enclosure for my first Car PC. I've never fiberglassed before and am wondering if it is OK to like make a base then, after it dries, add to it. I am making toe case to fit on top of my dash. So I was thinking of laying foil or something on top of the dash (to stop it from molding to the dash it self) and laying fiberglass over the top of the foil to get a perfect fitting base. Then I was going to attach all my parts to the base and build a wood frame or something for the top and sides and fiberglass like you would a sub enclosure for the rest of it.
    Does that sound like it will work?
    '93 Toyota Celica - First Car PC install
    Current System Specs:
    ZOTAC GF8200-C-E AM2+ GF8200
    AMD Athlon 64 X2 3800+
    1 GB DDR2 667
    LITE-ON DL-8ATS Slot-Load
    750 GB Seagate SATA HDD
    250W PSU
    19" Hyundai Monitor
    Jan 2008
    i have not layed any 'glass yet, but from the info that i have read, you are on the right track-- just make sure to roll out the foil so that it is as flat as possible.
    i believe that you can also use painters tape for the same thing...
    Jul 2009
    Painters tape? is that that blue masking tape or something else?
    1 GB DDR2 667
    250W PSU
    19" Hyundai Monitor
    Jan 2008
    yup! you basically just want to keep the resin from attaching to the stuff you don't want it to-- so serand wrap, tin foil, and painters tape seem to be the more popular options because they all seem to release with minimal effort from the form.
    Jul 2009
    alright. thanks for the tip. Now I just need to figure out the layering. I'm assuming that the more layers, the stronger it is?
    Also, is it better to apply the fiberglass cloth all torn up or in large pieces?
    1 GB DDR2 667
    250W PSU
    19" Hyundai Monitor
    Variable Bitrate djvillar's Avatar
    Sep 2006
    New York, New York
    Get the blue tape and mask everything plus some. Then Get some 3M adhesive spray. Spray the dull side of the tin foil. then slap that onto the masking tape. Now get some turtle wax. Wax and buff the tin foil a couple of times. Your tin foil is securely in place and when it come time to pop out the mold, it'll come right off no problem.
    The purpose:
    Masking tape is not a vapor barrier which means it porous and will soak up resin. The resin will then get onto the dash. The tin foil doesn't allow the resin to got through. The masking tape provides a surface for your tin foil to stick to, and being that the foil will have 3M on it, you can get a pretty perfect surface.
    Jul 2009
    I see. Good to know. I dont want resin all over my vinyl dash!
    1 GB DDR2 667
    250W PSU
    19" Hyundai Monitor
    Jul 2009
    I just realized. The area I'm covering is a pretty large area on my dash. I might need to piece together a couple sheets of foil. What would be the best way to do that?
    1 GB DDR2 667
    250W PSU
    19" Hyundai Monitor
    Jan 2008
    Quote Originally Posted by djvillar View Post
    The purpose:
    wow, i'm glad you chimed in before i encouraged him to screw up his dash...that could have been bad...
    i *think* that the adhesive will hold the multiple sheets together so that the resin will not soak through.
    Sep 2006
    New York, New York
    Quote Originally Posted by cjrokke View Post
    Like i said before you tape everything off then spray 3m on to the dull side of the foil. Let it tack up for a sec then slap it onto the masking tap. It'll be like contact paper... just slap it on.
    Overlap the tape when you lay in down and cover way more then you think is needed. DEFINITELY over lap the foil. DO NOT put it edge to edge. I'd rather over lap the foil 6" and waste a bunch then overlap too little and find my dash soaked with resin. Overlapping the foil is whats going to keep you from spending hundreds on a new dash.
  1. Replies: 2
    Last Post: 05-02-2006, 06:15 PM
  2. HELP PLEASE, Fiberglassing question.
    By Pokiarchy in forum Fabrication
    Last Post: 12-11-2005, 03:48 PM
  3. fiberglassing skeleton question
    By munozsblazer in forum Fabrication
    Last Post: 09-05-2005, 10:14 AM
  4. Paint And Polish Question
    By gboy in forum Fabrication
    Last Post: 08-13-2005, 08:22 PM
  5. FM Card Question....
    By Superbike1k in forum Car Audio
    Last Post: 05-16-2005, 10:03 AM
