Page 4 of 4 FirstFirst 1234
Results 31 to 39 of 39
Thread: How-To: Demon-Eye, Projector lighting
  1. #31
    Mar 2006
    Colorado, but Canadian!
    Does look good!
    Have you posted on hidplanet.com? http://www.hidplanet.com/forums/index.php
    The whole site is devoted to headlight retrofitting, and you should post some more detailed install pics over there.
    I am getting ready for my third retrofit as well
    1.9in x 2.9in -- 47mm x 73mm
  2. #32
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    once i'm done with my car PC install (yea right) i'm going to attempt a retrofit on my RSX. The darn thing should have came with HIDs in the first place.
    Live mp3Car Facebook Chat
  3. #33
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    God f#*king D@mn, now that Infiniti looks evil..... WOW. So what did he do, add two different color options? Red and White?
    In the past, I have noticed that Police only b!+ch if the lights are flashing, simulating a Police car. The red you guys are using isnt even close to or as bright as what Police use.
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
  4. #34
    Jan 2008
    Quote Originally Posted by ZX1Cruizer View Post
    the cops in my area don't take to kindly to lighting mods--i had some blue led lisence plate bolts on my old car--and got ticketed in 2 days for those, so it aint worth the chance for me.
    it is actually 2 different effects-- the red is behind the projector lens, so the lens ditributes the light, and the white led strip wraps around the outside of the lens, and reflects off the lens for the second effect (on mine, i used red led's for both effects because i already have a white halo, otherwise, i would have done it very similar.)
  5. #35
    Jul 2007
    Miami
    AHHHHHH, Thats cool. I was going to buy normal headlights, but maybe I will get projectors so I can do this mod.
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
  6. #36
    Jan 2008
    Quote Originally Posted by 2k1Toaster View Post
    Does look good!
    just wanted to let you know that my bank acount is going to hate you for that link
    i had a couple ideas for led tail lights, even got some superflux 180 degree led's, but now, every thread i open over there gives me another wallet-busting idea...
  7. #37
    Mar 2006
    Quote Originally Posted by soundman98 View Post
    Oh yes... I first wanted to put HID kits in my reflector housing civic, then it morphed into a full blown retrofit with RX350-AFS projectors, Acura TL Clear Lenses, custom cereal box spacers, custom cutoff shields out of tin, and it goes on and on... Now I am working on a quad setup with 110W lowbeam output each side, so 220W of optic power all with a perfect cutoff and done correctly.
  8. #38
    Jan 2008
    just a quick update(also added it to the first post)-- after researching some other projects, i have located a bunch of sources for the high flux led's i used here: just search google using terms like lenseless, flat lens, or flat top high flux led. it will return with a binch of lists of suppliers that might be closer and cheaper than "da shack"...
  9. #39
    May 2010
    Herákleion, Iraklion, Greece, Greece
    nice work man. i have a question though... i am planing to do something like that, and my research has shown, that the leds will burn out if they work in the heat of the projector, so you have to turn them off when the HIDS are working... how is yours done??
  1. a spider landed on my eye ball
    By will1384 in forum Off Topic
    Last Post: 09-04-2006, 07:33 PM
  2. Lilliput Remote Eye Question w/pics.
    By TCalYen in forum LCD/Display
    Last Post: 09-03-2005, 09:47 PM
  3. Is it possible to replace the original remote eye? (Lilliput VGA)
    By Erik N in forum General Hardware Discussion
    Last Post: 07-10-2004, 09:14 AM
  4. irman eye
    By freestyler in forum General Hardware Discussion
    Last Post: 09-18-2002, 06:51 PM
