Results 1 to 10 of 12
Thread: Calling all experts...
    Jan 2010
    Chevy Suburban 2009... I added an LCD screen to the front passenger panel. 5.8 inch in size. It barely fits. The woodgrain plastic is slightly curved from top to bottom so it leaves a gap on both sides of my screen. I want this installation to look as close to factory as possible. Any ideas would be appreciated on how I can clean this install up and not make it look like a hole
    Thank in advance for anyones feedback.
    Pictures here...
    Variable Bitrate VmtSquad's Avatar
    May 2007
    Montréal, Quebec, Canada
    I would look into some bondo products or even Dynatron 660, really easy to work with. Seems like you don't need much.
    Maybe Nexson will join and you'll get a better and complete answer
    Good luck bro!
    VmtSquad - I sold my soul to Honda!
    Final Install
    CarPC progress: 95%
    Jan 2008
    i am by no means an expert, but heres my opinion:
    i would use some bondo to fill the gap on the back, but i would also round over and /or cut on a 45deg. angle, the edges of the dash piece around the screen, so that it doesn't have such a fresh/jagged/hacked in look to it, and has a much smoother transition between screen and dash, but that would need a new water transfer afterwards, so it depends on how far you want to take it...
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    It would be easier to make suggestions if we knew how the rest of the dash looks, and thus what OEM appearance you're trying to match. Specifically, how are transitions like this made in other areas of the dash? How does the edge of the instrument cluster look? How is the head unit integrated?
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
    Jan 2010
    Ok thanks! Here is a pic of the panel and stock head unit... The LCD I am installing is on the right top woodgrain piece. You can see from my pics what piece I'm working with.
    Jan 2010
    My first bezel..
    Well it was a small bezel but a lot of work. I used Turbocads tutorial and other information on this board. Thanks everyone for all the contributions.
    Oct 2009
    Jerrabomberra, NSW, Australia
    Smile
    Top job, well fixed.
    VENDOR - Nexations Creations Nexson's Avatar
    May 2007
    wow that is sweet!, still dont get how you did it lol
    Brian @Nexations Creations
    Specialist in Custom Interior Fiberglass OEM Replication Work.
    AIM: Exus28
    E-Mail: [email protected]
    Jan 2008
    i can see you at car shows already: "i swear, it just came from the dealer like that..."
    nice work!!
    Jan 2010
    Quote Originally Posted by Nexson View Post
    Yeah it wasn't the most gracefull solution. I took a metal ruler and cut it in half and used it as the frame and straight edge that would meet the lcd. I mounted the bezel from behind, so when I moulded the Dynatron with tin foil I had to first put the tin foil through the hole from the top and then weave it through the custom metal frame. I have some more pics I will post that might better explain it. Either way, I stuck to what Turbocad mentioned in his post... Don't move to the next step until you finish the one your on and it can't be any better. I kept adding and sanding, adding and sanding. Anyway, it was a fun project. Im installing into the truck this weekend. I will post the pictures of the install.
  1. Calling all XM experts... 2 antenna wires vs. 1
    By Nola111 in forum Car Audio
    Last Post: 03-10-2009, 07:13 AM
  2. Calling all Lilliput Experts! IR problem
    By darkhalo in forum LCD/Display
    Last Post: 11-24-2004, 03:09 PM
  3. Calling all fish experts
    By cproaudio in forum Off Topic
    Last Post: 02-16-2004, 07:09 AM
  4. Need urgent help calling all software experts
    By Mastero in forum Software & Software Development
    Last Post: 02-15-2004, 02:47 PM
  5. Calling all audio experts
    By marcos_guy in forum General Hardware Discussion
    Last Post: 11-10-2002, 09:23 PM
