Results 1 to 10 of 18
Thread: How would you move a deck to the cubby hole?
    Low Bitrate volvoman1's Avatar
    Jan 2010
    Don't mind the stock double din in the picture. I have a single din unit in my car and would like to move the head unit to the cubby hole above to give me a double din space for a carputer screen (7" Lilliput). I removed the dash and found out a few things:
    1) The cubby hole can be removed and you will be left with a 7" wide and 1.5" din high opening.
    2) The flip up panel of the cubby hole can be removed but the cubby hole slot is too small to fit the single din head unit in (wishful thinking)
    After removing the cubby hole, i'll be left with an opening that can fit my head unit. My problem is, how do I mount it in there? There are no supporting bits in the dash I can use to mount my head unit. Its just a flat dash opening and nothing behind it. For reference, the cubby hole is mounted to the dash by screws. Tabs on side of the cubby hole allow screws to screw toward the back of the dash to hold it in place.
    Ideas would be appreciated...or pics if someone has done something like this
    Jan 2010
    more pics would help
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    If you're not going to use the mounting points currently being used by the single din unit, you can build a steel support (bar or panel) attached on these old mounting points going all the way up to the new position.
    Something a bit like this, only it's upside down on the picture (ignore the front and middle parts, of course). It would go from the existing mounting points all the way to the top where you need it. If you use bars, you may need to brace them, if panels, maybe not.
    Jan 2008
    to add to what ripplinghurst said, most aftermarket radios have a threaded hole on the back in the middle just for this. most radios also include a metal strap with them that is thin enough to bend to the correct angles.
    if you can't find it, try to find a generous car audio shop to give you one or 2(or check their dumpster )-- they usually don't use them, so they should be easy to get...
    just get creative with teh strap, and use either small screws, or epoxy to attach it to the bezel, and it should turn out great.
    just post pics when your done!
    Jan 2010
    Great idea, thanks guys
    Dec 2007
    Danville, CA
    That looks great!
    Jan 2010
    works great too. holds reall strong. bybyte doubledin ordered for the doubledin opening now.
    Jan 2008
    it looks like it was supposed to go there. nice work!
    Sep 2005
    Bay Area
    Quote Originally Posted by volvoman1 View Post
    Great work! I'm not familiar with the bybyte unit, but it looks like your deck angles downward and may limit the amount of depth it might take up. You may want to take some measurments or re-angle the deck a little bit. If you're into more serious fabrication, I would remove the deck's trim ring, flush mount the deck with the dash, and make a custom trim ring to fill in the space.
    Dec 2007
    Danville, CA
    But he said it's just for a screen, so I guess it's more than enough?
  1. Power the speakers: Deck or 4 channel amp?
    By rbsx in forum General Hardware Discussion
    Last Post: 04-11-2007, 01:39 AM
  2. My take on Street Deck.
    By pcmofo in forum StreetDeck
    Last Post: 03-15-2007, 02:35 PM
  3. Archive
    By Bitoholic in forum Mobile Media Center
    Last Post: 09-21-2006, 06:59 PM
  4. harness or deck?
    By precision4 in forum Car Audio
    Last Post: 07-23-2005, 08:09 PM
  5. Quickest Way to Move Files
    By KingsDude in forum Newbie
    Last Post: 03-15-2005, 01:00 AM
