Results 1 to 2 of 2
Thread: ABS Sludge vs ABS pipe Cement
    Mar 2010
    Is ABS sludge (made with acetone + abs shavings) the same thing as black ABS pipe cement?
    Also, when I make ABS sludge, lego's will work correct? Since they are ABS?
    Is it possible to use ABS sludge OR ABS pipe cement as a filler? Say I have a gap (in a piece of ABS) about 1/6 inch deep, 'bout 1 in wide and 5 in long. Good enough to use as filler?
    Thanks, I'm a noob
    Sep 2007
    this is actually something i use on a daily basis for just that reason... however, instead of using straight acetone, i use cyano acrylic glue. there are 3 types of ca glue that i use, extra thick, gap filling, and extra thin. but what i do is sand down a sheet of abs with a D/A sander and some 80 grit. collect the dust, spread the dust on the 2 pieces of abs i wish to bond together, add a few drops of the extra thin ca glue, and stand back, cause the fumes are awful. but it causes it to super heat and bond together. now typically gap filling ca glue doesnt stick to plastics, but if you use the extra thin and abs dust, the gap filling ca will stick to the extra thin. so for any minor pin holes that may need filling, put a couple of drops of the gap filling then spray it with the activator, and sand smooth.
  1. ABS sludge keeps bubbling up in heat
    By ak47clown in forum Fabrication
    Last Post: 05-10-2009, 12:03 PM
  2. Problems with the ABS sludge method...
    By zapro in forum Fabrication
    Last Post: 04-25-2008, 02:31 PM
  3. ABS sludge
    By rgarjr in forum Fabrication
    Last Post: 03-11-2008, 12:18 AM
  4. My try at ABS sludging a xenarc
    By evandude in forum Fabrication
    Last Post: 08-09-2006, 01:20 AM
  5. Salvaging my ABS sludge install with fiberglass?
    Last Post: 02-11-2006, 06:22 PM
