Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 32
Thread: 10.4" lilliput/mac mini + audio worklog - 03 chev blazer
  1. #11
    Low Bitrate RonsRed88's Avatar
    Aug 2009
    Western Washington State
    That bezel turned out great. Nice work!
  2. #12
    Jan 2008
    Quote Originally Posted by edge2k View Post
    Another question, can i re-title this thread to be a worklog im still pretty new to the forums and i have a few of other things in progress id like to post (custom door panels, fiberglass speaker pods and a woofer enclosure etc) without creating a whole new thread.
    you can do this either by editing(click on the advanced editing) the first thread, or by creating a worklog in the 'show off your project--worklogs' section.
    otherwise, it looks great so far!
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
  3. #13
    VENDOR - Nexations Creations Nexson's Avatar
    May 2007
    wow, looks like it is ready for paint, wetsand with 400 grit and your good to go!
    Brian @Nexations Creations
    Specialist in Custom Interior Fiberglass OEM Replication Work.
    AIM: Exus28
    E-Mail: Exus28@aol.com
  4. #14
    Low Bitrate edge2k's Avatar
    Jan 2009
    Daytona Beach, Fla
    Wasnt feeling great the last 2 days, took off of work and felt good enough today to not be a lazy sadsack, picked up some marine resin and supplies and got the console in and laid down the first coat of resin.
    Still drying currently, hopefully can lay down some matte later tonight.
  5. #15
    Jan 2009
    Daytona Beach, Fla
    Managed to put 2 layers of 1.5oz matte down gonna let it dry over night, put on some fiberglass filler tomorrow after work and hopefully get some rough sanding done.
  6. #16
    Jan 2009
    Daytona Beach, Fla
    Made some more progress last night, i have my console sanded to the point im happy with it i just need to pick up some more primer today to finish it up then ill post pics of it, also made a lot of progress on my woofer enclosure its almost finished already i skipped the beginning pictures since its not exciting to see pieces of wood cut out but leave me some feedback on the progress.
    Basic shape, meets to the top edge of the back seats
    I like to use tshirts over fleece since it takes less resin to harden the initial shape, but couldnt find a shirt large enough for the top and all wal mart seemed to have was this spongebob clearance blanket lol.
    The picture from inside the box is to show what iv learned makes the job much much easier, if you leave the back off of an enclosure after the initial shape is hardened it gives you the ability to add your fiberglass from the inside which keeps the original shape much better, i normally add a thin layer of matte and some fiberglass filler to the outside just so i dont sand down to the cloth material before primering.
    The box itself is 3cuft per chamber with 3" ports tuned to 35hz for 2 arc audio Kar-12 dual 4 ohm woofers (250wrms handeling), an ard audio fd1200.1 1200 watt amplifier (much overkill but id rather have more power and less clipping then underpowererd and an ard audio fd4150 4 channel amplifier for 4 sets of component speakers (1 set in each door and 2 sets in a pod on the ceiling) pics soon to come.
  7. #17
    Jan 2009
    Daytona Beach, Fla
    Welp heres the center console im really happy with how it turned out, tomorrow im gonna lay down some fiberglass over the carpeted area and fill all the cracks in so its 1 solid piece.
    The enclosure just has a few little things to go over, mostly tiny low spots and pinholes
    Probably overkill but ANY imperfection that i can see ill circle with a sharpie so i know exactly what to fill, sometimes it gets overwhelming when you have a few minnutes work time with your filler and a billion tiny holes to pick from lol
  8. #18
    Jan 2009
    Daytona Beach, Fla
    I made some more progress on my center console, got all the glasswork and most of the filling done, just have a few spots to touch up and do some fine sanding, im gonna TRY and at least get this box/sub and sub amp functioning by the weekend so i can hear this thing and see how it sounds.
  9. #19
    Feb 2009
    Impressive work, between you and nex I can see I have alot to learn and more people to ask for help when I eventually rasie the funds to start mine
  10. #20
    Mar 2010
    your build looks amazing!! Can you tell me the actual physical dimension of the 10.4? I want to try and put on in my 08 civic.
  1. FAQ: Installing a Mac Mini in Your Car
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-11-2011, 08:12 PM
  2. Audio issue with Intel Mini
    By iamgnat in forum MacCar
    Last Post: 06-27-2006, 07:01 PM
  3. Mac Mini Audio Help
    By dlowe062372 in forum MacCar
    Last Post: 08-31-2005, 06:52 AM
  4. Audio problems, Epia Sound, and FAQ stuff
    By gothate in forum Newbie
    Last Post: 06-16-2005, 04:04 PM
  5. Mini audio problems in car.
    By ApertureFoto in forum MacCar
    Last Post: 02-06-2005, 10:20 PM
Tags for this Thread
