Page 3 of 15 FirstFirst 12345678910111213 ... LastLast
Results 21 to 30 of 143
Thread: Fiberglassing Tips?
  1. #21
    Dec 2003
    Germany
    Quote Originally Posted by frodobaggins
    use cardboard covered in fiberglass
    Another idea might be to use this faom you can buy in a spray can. I don't know the English name for it, but it is used to fill the wholes between the wall and the door frame when buidling houses, for example.
    Use this foam and let it dry. You can cut it to the right size later and add a few layers of fiberglass.
    Just my 2 cents, especially since I haven't tried it myself yet :-p
    Lilliput 7" TS TFT, ASRock K7VM2, Duron 1,3 GHz, 512 MB DDR RAM, 30 GB Seagate HDD @ 5.400 rpm, WLAN w/ 500mW booster, Toshiba Slimline DVD-ROM Drive, D-Link USB Radio
    Download the German Voicepack 1.0 for FreeDrive now!
  2. #22
    Newbie Rob_Quads's Avatar
    Sep 2003
    I have used the wood frame + stretched cloth + resin + matting layers to great effect on my last few stereo installs. if anyone has any questions just send me a mail and i will try my best to answer them
    Soon I will be looking at making up a hosing for my new touchscreen.
    Here are a couple of examples of my work
    Carbon:
    http://www.users.totalise.co.uk/~rob.../interior4.jpg
    http://www.users.totalise.co.uk/~rob.../interior6.jpg
    Normal
    http://www.users.totalise.co.uk/~rob.../interior2.jpg
    http://www.users.totalise.co.uk/~rob...temp/206-1.jpg
    http://www.users.totalise.co.uk/~rob...temp/206-2.jpg
  3. #23
    Jan 2003
    Ruston, LA
    Quote Originally Posted by Rob_Quads
    Nice
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  4. #24
    Oct 2003
    Copenhagen, Denmark
    Just a little tip i learned while doing very oddly shaped fibreglass things. Try putting your subject into a plastic bag, tie the end around a pipe, prefrably with a valve that can be closed on it, then use a vacuum cleaner to make a vacuum in the bag, and the fibreglass will stick like crazy to the shape of the mold you are trying to use.
    Jan
  5. #25
    Mar 2003
    frontbumper
    I would like to make an nice frontbumper of fiberglass,
    Does somebody have nice ideas,proyect or sites?
    greetzzz
  6. #26
    FLAC mp3z24's Avatar
    Apr 2001
    Chicago Suburbs
    Quote Originally Posted by _dopehead_
    Jan
    just make sure that the vapors from the curing process are not flammable!!!! no one wants to hear about a guy blowing up his place b/c he was vacuuming up combustable gasses...
    also, unless you take the bag off quickly, wont the bag stick to the surface...
    ~Mike
    Single Member of the "1000 Post and No MP3 Car" Club
    PROJECT ON INDEFINATE HOLD... BOUGHT A HOUSE
    2000 Cavalier Z24 [###-------] Only 30% Done ... Still
  7. #27
    Apr 2001
    Chicago Suburbs
    Quote Originally Posted by jermaine
    greetzzz
    you would probably be better off starting from a stock bumper, rather than starting from scratch. the big key here is going to be making both sides exactly identical.
    i suspect, the best way to get a nice design is to negative mold one (read: expensive and time consuming). basically, you would form a mold that the bumper could fit into, and then carve out every last detail that you want to be in the finished product. but it would be a negative copy of the bumper.
    then after a lot of mold preperation, i.e. sanding, smoothing, polishing... you would be able to lay the fiberglass into the mold. and after several layers... you will have a bumper. with this process you can also reuse the mold to make more of the same item... until the mold wears out.
    like i said, that would give the best results... but it would be VERY expensive for a low production run.
    ~mike
  8. #28
    zvi
    zvi is offline
    Constant Bitrate zvi's Avatar
    Jan 2004
    Tbilisi, Georgia
    I am trying to mold the Lilliput screen to my dash also, I am using the fiberglass polyester (?) and first time, have a look, not completely done yet, I have not much to fiberglass, only the frame:
    http://zvi.home.ge/pics/?dir=vextra
    '93 Opel Vectra A with Custom Dash with 7" lilliput
    VoomPC/M1-ATX/M10K/256 RAM/20GB 2,5' HDD/Gemtek USB Radio/WinLite/RoadRunner
  9. #29
    Jun 2002
    Malaysia
    zvi,
    How did you make that? By yourself? Or by market available parts?
  10. #30
    FLAC Chairboy's Avatar
    Jan 2004
    Quote Originally Posted by Jeeve5
    I've been using that with my dash project, and I have a tip: Don't do too much at once. It needs air to cure, and if you use it to try and fill a big void, it will always have a juicy center that can't wait to turn into foam.
    I did this last night with my project (where I'm building an additional 'hump' on my Regal dashboard to house a lilliput) and by this morning, it looked like I had a perfect foam filled mold. I pulled the fiberglass + foam piece off the taped & foiled off dash and brought it upstairs to work on it. While cutting into it, my knife stuck, and when I pulled it out I found it had goey, uncured foam stuff on it. Of course, that stuff, now exposed to air and humidity, began to harden. Since the piece was no longer attached to the dash, the expanding foam warped the fiberglass base, so it no longer fits.
    As a result of this, I am now re-doing it with A: More then 1 layer of fiberglass and B: Adding foam one layer at a time and letting it cure. I already made the fiberglass base and have left it attached to the dash. It has a layer of foam in it curing right now.
