Page 6 of 15 FirstFirst 123456789101112131415 LastLast
Results 51 to 60 of 143
Thread: Fiberglassing Tips?
  1. #51
    Low Bitrate odleon's Avatar
    Atlanta
    oh, and for the hairball on the brush, dont actually "brush" the FG, its more of a dabbing or stabbing motion. that way you dont get fg on the brush, and you get out the air pockes(your worst enemy) also use the cheapest brushes you can get, you will not be able to use them again after youre done.there is also woven fg cloth. it looks like carbon fiber, but white, and not as strong.should be right next to the mat in the paint section of home depot, or in most auto parts stores.
  2. #52
    Atlanta
    damn i just relized this tread is old as hell.
  3. #53
    Low Bitrate IonDokk's Avatar
    Michigan
    Well I too have done a fair amount of fiberglassing I've found that if you use Spandex it will stretch in four directions. Other materials mentioned in the forum do not, this way you do not get any sagging and you can stretch to your hearts desire. Also on large flat surfaces you can use Speaker box carpet two layers of glass and your done. It does stretch if you get the right stuff and you also can do slight contours around subs and what not.
    Epia M1000 1.2gig, Toshiba 40gb HD, Itronix 60gb HD, 512ram,PCR, Audigy2zs, 2 Xenarc 7" , FRODOPLAYER Trying RR frontend , 2@1600/w Harrison labs amps & Caps, Focal & MB-Quart midrange, Diamond Audio D6 Subs, Mb Quart Tweets, 2-Audiocontrol three.1 !
  4. #54
    Constant Bitrate 98EXL's Avatar
    Mar 2005
    Maryland, USA
    so what I thought was true about FB is....sweet, taking the dive when my order of stuff gets here....props to the old thread
    Molded Screen:
    [++++++----] 60%
    DVD & Rest of audio:
    [++++++----] 60%
    2004 Accord Coupe, Satin Silver K24 5 Speed powa!
    7" Lilliput Screen, non touch with lots of Bondo
    NTB DVD player or put XBOX in car
    My 04 Accord Picture Thread
  5. #55
    Jun 2004
    The North, Manchester
    im gonna pop out my two center vents to make room for a screen and slim cd.
    this is gonna leave an awkward shape in my dash
    whats best, to fab up a module to fit to the shape left behind ortry and reproduce the whole piece (quite big)
    gonna nip down the scrappy to see if i cangrab an old one
  6. #56
    Jun 2004
    Forget it - its like my entire dash!!!
  7. #57
    Mar 2005
    Quote Originally Posted by cheerio
    OMG, i just did a test run on fiberglassing, and JESUS christ. OK, i was using fiberglass matt(there HAS to be an easier way) and the threading just brushes off with more brushing. Then i have a big hairball of matting. THEN my brushes are destroyed every time i do it, etc etc. NOW, what are easier methods than using matting, i was reading about foam, that seems very intresting and a lot easier than matting. Any suggestions?
    If you are using fg matt using a dabbing action.
  8. #58
    Variable Bitrate RS3RS's Avatar
    Aug 2004
    Springfield, MO
    Yeah, dabbing makes it a lot easier.
  9. #59
    Jun 2005
    Sorry for the resurection but I am sick of spending the money and waiting for someone else to do simple stuff I want, so I am looking into learning how to do this myself. I understand that it will take a while to learn but you have to start sometime so I want to start practicing on a bunch of junk until I get the hang of it.
    I am under the impression that you need:
    Thin Polyester Fleese
    Sanding Block
    Fiberglass Resin
    Hardener
    Fiberglass(choppmatt or Weave)
    Rubber Gloves
    Cheap Brushes cut short for better "stabbing" lol
    respirator
    measuring cup
    Pale
    mising stick
    Acetone
    Bondo
    Blue sand paper
    Is that about it? What is the difference between choppmatt and weave? And where can you get all these supplies? Mainly resin, hardener, fleece, riberglass, acetone , and bondo? And about how much am I looking to spend? If it eclipses the cost of someone else doing it...lol
  10. #60
    Mar 2005
    Maryland, USA
    I bought 10 square yards of chopmat, a gallon of resin (and hardner) 2 respirators, brushes, and rollers for $110 from www.uscomposites.com
    this is so simple to do, really, you figure it out as you go. AS for the difference between mat and weave, the mat is a giant cluster **** of strands, and the weave is more like fabric.
    Molded Screen:
    [++++++----] 60%
    [++++++----] 60%
