Page 1 of 15 1234567891011 ... LastLast
Results 1 to 10 of 143
Thread: Fiberglassing Tips?
    FLAC MP3DUB's Avatar
    Jan 2002
    Chicagoland, IL
    Fiberglassing Tips?
    So I've never fiberglassed before, and I just tried using a Bondo brand Fiberglass Repair Kit, and it turned into a biiiiig mess really, really quickly. Does anyone have any tips? Is the woven fiberglass matt easier to deal with? The fact that I tried to fiberglass a really oddly shapped cubby probably didnt help things, as hell didnt break loose until I tried to start working all the different angles and nooks and crannies in.
    Edit: This cubby
    -Nick
    _____________________________
    Monthly MP3Car Chicago Meets
    www.mp3vw.com Last updated: 07/07/2008
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    Ohh... I've fiberglassed a ton of crap in the last 6 months. It's difficult to get used to. ..Okay, in my experience fiberglass cloth is easier to mess with than fiberglass mat.
    As far as the cubby, this is what I'd do. Make a frame out of thin plywood or MDF. Then staple and stretch fleece (Sweatshirt material) over it and bruch on your resin/hardener. When it dries you can add layers of the fiberglass cloth to it to build it up.
    I'm making a little console for my AC controls that I had to relocate and it has a few curves in it (to match the dash, and this is the method I've used and it turned out VERY nice.
    Sep 2002
    Manitoba, Canada
    One point to add to `ddt` regarding the "fleece (Sweatshirt material)", try to find material with as much polyester as possible. It sets up better and there is some material that the resin will dissolve, try a test piece of your material with your resin first to make sure it's OK.
    Chkdsk
    Shuttle ST62K, 80Gb, MediaEngine, Irman, Wireless NIC, Win2K, Blah Blah Blah...
    Jan 2002
    Chicagoland, IL
    Did you steal my friends brain? Heh, he said the same thing. Only problem is I'm trying to do a shell inside the cubby. I'll have to go get some fiberglass cloth thins week, and some more hardener. Also, any tips on getting the fiberglass loose other than just prying?
    -Nick
    Sep 2002
    Manitoba, Canada
    Depending on what it is bonded to, you can try using some acetone or heat to remove it. But if it is attached to something soft, like plastic then be very careful. Prying may be your only solution; hopefully the resin is still a bit soft.
    If you're grabbing some cloth, maybe get some thinner (lighter) stuff and do multiple layers, it is much easier to form around corners. We used to put some different color paint in the resin so you could easily see the multiple layers as you are applying them, saves "guessing" where you left off...
    Chkdsk
    Sep 2002
    Manitoba, Canada
    To anyone interested, here are some more fiberglassing resources...
    The12Volt.com has a Fiberglass section (as well as other things)...
    Alpine-Usa.com 2003 Honda Civic SI, Click on the Installation Photo's - it will take you a few hours to go through BUT it is extremely informative!
    The Glassman Forum at YahooGroups - not a pile of posts but very informative. Kinda of commercial orientate but still a lot of good info. At YahooGroups, search for Glassmancustomforum and you'll find it.
    I don't know how far MP3Car.com wants to get into glassing as it is a growing part of our hobby IE; do you prefer we send people to other sites OR do you prefer we help them out here?
    Chkdsk
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    Bingo! But if the area was cleaned and prepped (meaning the resin will stick well) then good luck!
    Jan 2002
    Chicagoland, IL
    Yeah, ive done a bit of reading on the glassmans yahoo group, and im trying to get the haphazard shell out of the cubby now. I laid down a few layers of masking tape over the plastic cubby, so Ill just get to prying.
    -Nick
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    Sep 2002
    Manitoba, Canada
    Start "prying" as soon as possible as the masking tape will start reacting with your mold and with the resin making it a permanent structure of your vehicle.
    I use a good quality masking tape (7 day release) and usually apply Turtle Wax on top of the tape to assist in a mold release. You can also go one step further of using Tin Foil depending on how flat the surface is.
    Chkdsk
