Depending on the fiberglass mat weight/thickness is going to be up to you for the most part, i would take account that each layer will be slightly thicker then the mat itself once the resin is applied, i dont think your'e going to find an exact formula in this situation, your going to have to use some good ol fashion educated guestimation.
After all, you can always start smaller and add more as you need, it would be much easier then trying to sand down through the matting, thats just going to make a royal mess.
LinkBack URL
About LinkBacks
