Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: My recent work log
    Variable Bitrate djvillar's Avatar
    Sep 2006
    New York, New York
    My recent work log
    Here's some stuff I've been working on as of late.
    My neighbor had this awful crummy plastic bezel the he was using for some gauges. I made a new surface to house the gauges:
    I drilled holes through the mdf and plastic. Used quick set epoxy in a couple of ares just to hold it in place then CA glue for the rest.
    First layer of evercoat.
    A little sanding later.
    Sep 2006
    New York, New York
    More gauges: right above the center console in the no longer used vent
    Had to cut out the center division between vents and secure a new surface for the gauges
    After some evercoat glaze and sanding the edges to get a nice bezel/curved corners
    Here's a shot of an extra identical vent an the new "gauge plate"
    Here's a shot of the two together
    Sep 2006
    New York, New York
    Here's my cluster screen bezel. There were a bunch of versions and finishes. Initially I planned on this being an insert bezel so that I could go back to stock if I ever want to...
    I had masked the area and used epoxy putty to build the area around the hacked lilliput bezel [sanded with 40 grit first]
    Almost done
    Finish 1
    Way too flashy for me...
    Sanded it down and started trying a dupont flat black... I'm liking this better
    I finished this but decided to just go for a one-piece and go for more OEM look
    These edges were perfectly match previously but being that i want to join these pieces, I sanded it down to make a bit of a gap that I will fill...
    CA glue to bond the back
    Almost there
    I wound up using SEM trim paint. I covered the entire piece and baked it. Then I did a medium coat, allowed to tack, then followed with three dry shot coats from a far distance. This gives the paint a really nice texture. I'll have to get a closer shot for you guys to really see what I'm talking about.
    Sep 2006
    New York, New York
    Here's a piece under my cluster. A simple graft project... again I'm using epoxy putty, CA glue, and Evercoat glaze as a finish.
    I have to clean up some goo from the tape on the edges but i'll do that later...
    Constant Bitrate djchicago's Avatar
    Chicago Ill
    coming along nicely, what did you do with the power button for the screen?
    Sep 2006
    New York, New York
    I'm using the cigarette adapter for power. It turns on as soon as it gets signal from the computer. I'm installing everything on saturday. I hate taking the car apart for wiring...
    May 2009
    Your work looks very good! Sweet! I'll be keeping track of this one :-)
    Sep 2006
    New York, New York
    Quote Originally Posted by djchicago View Post
    Now that I have everything installed I see what you mean. I thought the monitor would come on if given power and signal from the VGA... I was mistaken. I've tried that "factory menu code" 588998 to no avail. I tried it so many different ways... I'm done with it. I cut off the button portion of the lilliput and glue it to the back. I will relocate the buttons to where i put the usb's/audio. I may be deluding myself, but I actually like having the option of turning the monitor on/off with the button if I so choose.
    Quote Originally Posted by Wirecase View Post
    Thanks dude.
    Sep 2006
    New York, New York
    More work:
    Fabricating a place for the Lilliput controller board and a center channel.
    Sep 2006
    New York, New York
    Updates:
    Update:
    Now to wet sand paint,
  1. 2003 VW GTI 20th AE Work Log
    By trititan in forum Show off your project
    Last Post: 02-21-2010, 01:37 PM
  2. Stealthy surfing at work?
    By e_z_street in forum Off Topic
    Last Post: 10-07-2009, 03:30 AM
  3. Does FluxMedia own rights to our skins?
    By justintime in forum CF Skins
    Last Post: 09-03-2006, 08:22 PM
  4. Replies: 22
    Last Post: 01-05-2005, 01:47 PM
  5. Replies: 4
    Last Post: 11-18-2002, 09:59 PM
