Results 1 to 5 of 5
Thread: Speaker rings....
    Jun 2010
    Speaker rings....
    First post here....noob from Cali
    I have done a lot of projects with carbon fiber and fiberglass, but I'm not too familiar with speakers and amps...
    For the speaker rings, what are good dimensions? I'll be using 3/4 inch MDF.
    What would be good measurements for a 10"? 12"?
    ID and OD would be great, thanks!
    Vendor - Qube colin's Avatar
    Dec 2006
    Well your speakers will come with a template... for mine, the inner cut diameter was 11 1/8" for the 12" subs. Then theres 7/8" for the screws, then most people leave at least 1" on each side (2" added to the diameter) for a countersink type of feel.
    That's what I did anyway.
    Jun 2010
    Thanks!
    I see all these guys building fiberglass boxes for their trunks...and I was wondering where the speaker rings get their strength from...Is it the fiberglass? It seems like the dowels supporting it wouldn't be strong enough for the sub thats going to be mounted in it.
    Dec 2006
    Yeah, its the fiberglass. The dowels are only there to hold the rings in place while you fleece over them. Once a layer of resin goes down, the dowels can come out if you want them to since they're just taking up space. Then you fiberglass until it's strong enough to hold everything.
    I'm in that process now actually! Ahh!
    Jun 2010
    Thanks Colin, that's what I was thinking
  1. Integrating carPC with BMW E38 wide OEM nav LCD+TV module
    By coolshark in forum General Hardware Discussion
    Last Post: 06-01-2010, 01:49 PM
  2. Please advice on weird headunit to amp ?
    By mrcgibb in forum Car Audio
    Last Post: 03-16-2008, 05:29 PM
  3. Speaker Blown???
    By 3onDubs in forum Car Audio
    Last Post: 03-10-2006, 12:55 PM
  4. Speaker Rings
    By Giwo in forum Fabrication
    Last Post: 02-28-2005, 05:43 PM
