Results 1 to 8 of 8
Thread: iPad Headunit Install
    Sep 2009
    Hey guys, I'm just starting fabrication (I'm a beginner, never done this type of thing before, but am tackling it anyway!) of a fascia piece to fit my iPad in as a head unit.
    I started with a cardboard mould and bondo'd it up to sit kind of snug, but it wasn't strong or durable enough to do anything. So this week I'm starting on the frame with plywood, and I'm thinking of using bondo afterwards, would this be a good method of attack? Or should I be going for epoxy's and/or glassing?
    Any tips for a beginner? As soon as I get the wood it will be documented in this thread.
    -RDCTBR.
    Sep 2009
    Brilliant advice guys.
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    More detail about the car, pictures would help gather some interest. Previous experiences and showing what you learned would also help.
    AFAIK, bondo is not a good idea to use it a car. I think it breaks and it does hold well over time. Have you heard about plastic welding? That's the direction I would go first, if I want to fully integrate with the OEM dash.
    If you use fiberglass I would think you would use automotive paint over it and make it looks like those show cars (i.e. not oem like at all)? Fine if that's what you're aiming for, but you should be clearer.
    Just my .2c
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Want to:
    Jan 2008
    eh, the lack of posts just means that their afraid you'll do better then they can do ;P
    i saw your post originally, but figured i would leave it for the more seasoned expert that actually did some dash fab(i have never done any fab work to a car...)
    bondo is a very stiff substance, esp. if used on a flexible base like a dashboard/radio bezel..
    the common approach seems to be to find a similar plastic/material as what the original part is made from, and add/subtract what is needed for your design, then finish with the new, same-type platic.
    the idea behind this is that all of the part, both the old component, and the added material will then have the same expansion/contraction characteristics, so none of it will break and crack later on..
    and here is a better link then bugbytes(funny part is that it's found in the top part of this fab section-- just below the button you had to click to make a new topic): how to make a factory bezel
    Constant Bitrate NoTec's Avatar
    Jan 2009
    South Florida
    Quote Originally Posted by RDCTBR View Post
    Posts like this make me never want to reply to initial postings.
    Low Bitrate war085's Avatar
    Mar 2010
    Quote Originally Posted by notec View Post
    posts like this make me never want to reply to initial postings.
    +1
    Apr 2009
    Blog Entries
    1
    Hey, welcome to this forum!
  1. 1994 Peugeot 106 XS beeing upgraded just a bit
    By boelle in forum Show off your project
    Last Post: 10-16-2010, 02:41 PM
  2. Dodge Charger iPad Install
    By MobileEVDO in forum Apple iPad
    Last Post: 09-04-2010, 02:23 AM
  3. Newbie Set on Mac Install
    By The_Blade in forum MacCar
    Last Post: 06-12-2008, 03:16 AM
  4. what is the smallest headunit?
    By Snortonnorton in forum Car Audio
    Last Post: 03-14-2008, 09:10 PM
  5. VW Golf IV - Mac Mini install
    By Fuse314 in forum Worklogs
    Last Post: 02-24-2008, 05:25 PM
