Results 1 to 10 of 11
Thread: Painting Plastic - Best Practices
    Jul 2010
    I want to change the interior color of my German truck from mid blue to grey.
    What are the best methods and products for doing this? Obviously cleaning the removed sections is important. What should I do to ensure a long lasting professional looking job? Thanks.
    Jun 2010
    i would like to do the same. im scared of the paint layer cracking due to expansion/contraction from heat changes because the material is kind of soft almost rubbery
    Variable Bitrate djvillar's Avatar
    Sep 2006
    New York, New York
    I did a civic a while back. It had a hard plastic interior. Clean everything with a degreaser, then sand everything with 200 or 300 sandpaper. Then paint. I used a matt dupont black. Everyone thought it was stock. Its held up fine for as long as i've had it, since 98. Got rid of it in 94 or 95.
    Vendor - Qube colin's Avatar
    Dec 2006
    Quote Originally Posted by djvillar View Post
    Hahaha!
    But easy enough, clean it well (soap, degreasser, whatever) and then sand it with a decently high grit. Use good paint, that's all I can say. Paint intended for lightly sanded plastic. Krylon has a good line, "Fusion" I believe, which holds to plastic specifically.
    Sep 2006
    New York, New York
    Also spray extremely light coats and bake dry. If your cover the sub materials color on the second coat you're laying it on too thick. When I did it, i let it bake dry between coats and didn't get full coverage till the 4th coat.
    If you put it on thick it will especially without sanding first, you'll be able to scrape an edge up and peal it off in one piece like unupholstering a chair.
    Sep 2006
    New York, New York
    Quote Originally Posted by colin View Post
    Hahaha!
    Sorry for the dyslexia... 94 or 95 that I got rid of in 2004.
    Maximum Bitrate david69leonard's Avatar
    Oct 2006
    Texas
    You need to make sure that you clean the dash with alcohol, also use an adhesion promoter and primer
    I painted my whole interior 4 years ago and it hasnt chipped or faded, i used dupli-color vinyl and fabric coating at autozone, its good on dashes doors seats and carpet
    Also sanding the plastic bad idea, it will make the finished product look like ***, most plastic dash components are textured, unless you plan on spending all day making it smooth removing all the scuff marks from the sand paper, resorting to filler primer in the end, dont do it, lol
    Sep 2006
    New York, New York
    Sanding wont ruin the surface,.. if you use the right grade, 200 or 300. Of corse using a 40grit will leave the surface chewed up. But just like you sand paint bewteen coats, so do you sand to prep for paint. You're not look to shape the piece as it is already the a finished piece, but sand (fine grit) will give you better adhesion.
    Oct 2006
    Texas
    What do you mean by "bake dry"? Putting plastic in the oven is also a bad idea, lol
    Sep 2006
    New York, New York
    Quote Originally Posted by david69leonard View Post
    Heat lamp dude. Getting the solvents out of the paint to speed curing and minimize the effect of shrinkage leading to cracks with multiple coats...
  1. Plastic Welder - anyone used?
    By evandude in forum Fabrication
    Last Post: 11-15-2010, 11:55 AM
  2. Replies: 3
    Last Post: 03-21-2008, 09:01 PM
  3. Help With Sanding and Painting Interior Plastic
    By xhazn in forum Fabrication
    Last Post: 05-06-2005, 08:18 AM
  4. Painting plastic
    By C4M in forum General Hardware Discussion
    Last Post: 10-26-2002, 03:04 PM
  5. Painting plastic
    By petemal2000 in forum General MP3Car Discussion
    Last Post: 10-07-2002, 08:13 PM
