Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: my sunburnt dash restoration
    Jul 2010
    Hi guys, This is my first time posting but Ive been a long time viewer. Anyway the story goes, I've got my first car everything is in good nick except for the dash. It has about 4-5 major cracks and i want to restore/better it than the original. Because this is my daily driver i managed to pick up a free dash which is in similar condition. Ive striped the main material off it and the pics bellow is the result. This is where i need help.... I'm thinking of putting a resin over the foam, do a couple of layers of fiberglass, sand and bondo it back to a nice smooth finish then use Sem texture paint and trim black paint to get a more modern original look. will this work? how will the fiberglass go in the sun? better ways to do it?
    I'm a student to, so don't have heaps of money...
    how it sits
    only small parts of the foam are like this
    sun burnt goodness
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    I'll let the experts weigh in on whether there is a specialty replacement material for this purpose. Otherwise, your approach sounds like how I would try it.
    If you have gaps in the foam, I'm thinking that some of that home insulating foam might work for you - goes under the name of Great Stuff here in the states. It sticks like crazy to anything and expands when you apply it. I'd apply it to the gaps and let it overexpand, then let it dry completely. After that, cut it with a knife and try to shave it into shape. It's not quite as dense as the foam on the dash, so there may be another product that is better, but that's what comes to mind.
    Here's an article on using spray on plastic truck bed liner to get like-new results. Might work for you.
    Want to:
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    I suspect if you just try to add foam and recover, it will crack again.
    I think you are on the right track. I would strip it, wrap it in fabric (preferably Ponte), resin it, then add 2 layers of mat/resin and do body work with Rage Gold, sand and paint. It should be good for life then!
    Jan 2008
    i am thinking you should use something more pliable then bondo/ resin-- either material might too different then the original material, so the hot/cold shrinkage rates of the 2 materials might cause separation later on down the road. though i really have no idea what you would need..
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    I am no F/G genius but I have researched this proceedure and it is apparently done regularily with good results. I offer it up only as ideas to draw your own conclusions from.
    I have done a bit of F/G work but I have never laid up a dash.
    My understanding is that basically by adding the mat/resin, the original dash would just be the mold and attachment points to the vehicle. The dash would be solid fibreglass at that point and the filler is designed to be used with F/G. Any movement under the glass dash from the orginal dash shell should have no effect on the solid F/G shell.
    Just more food for thought!
    Jul 2010
    Thanks guys, ism thinking I'm gonna give it a shot.. its also my first time fiberglassing, I've done a fair bit of reading and watched a lot of youtube videos and is it really that easy? is all i need just some fiberglass mat and resin? would just an all purpose fiberglass resin do in this case? is Polyester resin ok? any further links would be great
    Thanks again
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    Maximum Bitrate david69leonard's Avatar
    Oct 2006
    Texas
    fiberglass resin and a layer or two of matting should do the trick, then you can sand and apply vinyl or paint, vinyl will give you the texture you are looking for, when heated it will stretch very nicely, liquid nails or a spray adhesive to secure it.
    Jul 2010
    so would something like this do for the resin?
    http://cgi.ebay.com.au/MOTOSPRAY-NEW...item4aa3486473
    and this for the mat?
    http://cgi.ebay.com.au/Fibreglass-Ch...item1e568fc382
    What does the 300grm mean? how much of each would i roughly need?
    Thanks for those links Phil
  1. Help on custom dash for Caddy STS
    By Slaughterhouse in forum Fabrication
    Last Post: 12-14-2006, 07:47 PM
  2. Fun with a spare dash
    By muniom in forum Fabrication
    Last Post: 11-22-2006, 02:20 AM
  3. Attaching monitor cable to dash.
    By voyager1713 in forum General Hardware Discussion
    Last Post: 06-23-2006, 09:01 PM
  4. LCD Central Dash Accord 96
    By teh Gone in forum Fabrication
    Last Post: 03-22-2006, 05:34 PM
  5. In dash or Not in dash that is the question
    By belezeebub in forum Fabrication
    Last Post: 12-10-2004, 06:18 PM
