Results 1 to 5 of 5
Thread: Fiberglass Jeep Top
    Low Bitrate capcadetjc's Avatar
    May 2008
    Lubbock, TX
    Fiberglass Jeep Top
    Hi all. I am trying to find a good site to learn how to use fiberglass. I would like to start with a small project making a mount for my carpc monitor and then move to a big project of making a hard top for my jeep wranger. I want to learn as much as possible before beginning and would like to know if any of you can point me in the right direction. Ive done a few quick google searches but didnt pull up much. Thanks for any help.
    My 2007 Jeep Wrangler Worklog
    Mod - all of it. SapporoGuy's Avatar
    Aug 2009
    SonyLand
    Look in the fabrication area here in the forums. Lot's of good stuff.
    As for a hard-top??? lolo, that's a lot of material, time and cash.
    Are you thinking of being creative? IF not, maybe just buying a cheap crappy one and refurbishing it might make more sense.
    Jan 2008
    i think it would be better/easier to get a premade top..
    fiberglass can be very brittle, so if your jeep flex's a lot(like while off-roading) you could crack the top...
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    Check out Nexson's posts here. He's one of the fiberglass fabrication masters.
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
    Sep 2008
    for your top for the jeep, polyurethane foam will be your friend. Can bond it together with epoxy resin with cabosil or microballons. then sand it to shape. Spray on more resin with microballons. sand the surface then lay the glass. body work the glassed top with body filler, sand and paint. creating a home made hard top for your jeep with a foam core structure. glassed inside and out. could even make an enclosure for your screen in the top.
    there are other composite materials such as nidacore that can also aide you in your project.
  1. Fiberglass subwoofer box.
    By 0828546333 in forum Fabrication
    Last Post: 04-20-2009, 06:27 PM
  2. First time Fiberglass questions
    By PBFreak817 in forum Fabrication
    Last Post: 06-21-2008, 07:25 PM
  3. Top of screen shrunk down 1" at top...
    By kamlung in forum Newbie
    Last Post: 10-26-2005, 05:40 AM
  4. FS: SF Bay Area: Optima Yellow Top
    By VanMan69 in forum Classified Archive
    Last Post: 08-19-2004, 03:17 PM
  5. Non-permanent fiberglass mount
    By Chairboy in forum General Hardware Discussion
    Last Post: 03-21-2004, 03:33 AM
