Results 1 to 8 of 8
Thread: ideas requiredd
    Sep 2010
    ideas requiredd
    i have a punto mk2.....the screen will have to be mounted how this guy has done it....
    http://www.fiatforum.com/punto-guide...nel-gars2.html
    but i will need to cover the screen somehow when not in the car as i cant have it on show.....any ideas///
    Mod - all of it. SapporoGuy's Avatar
    Aug 2009
    SonyLand
    Towel or possibly making another faceplate that was older audio looking device.
    In college, I my helped my friend take his old Toyota radio apart to make a cover for his alpine. Sitting in the car you knew something wasn't right but from outside ... no problems.
    Variable Bitrate djvillar's Avatar
    Sep 2006
    New York, New York
    fabricate a faceplate that covers the screen plus a half inch on all sides. in the corners glass in pins or nails. these nail/pins will correspond with pin/nail holes in the monitor housing. when you leave the car you just clip it on to cover the monitor. It'll basically be like the mounting concept used for speaker grills in home theater speakers. Expect this one wont clip in, it just slides in.
    Sep 2010
    that sounds like a good ideaaa.....im just scared im going to **** it all up i havn't done anything like this beforee
    Jul 2009
    Get a busted double din stereo and just make a way for it to attach over the screen.
    '05 Magnum RT
    CarPC coming soon. Hopefully end of 2010.
    Parts left to buy-
    Monitor, Bybyte frame, Axxess hook up, Sheet metal for double din case.
    Sep 2010
    as standard this car has a single din.....to install a double din you have to remove the heater vents....so even with a busted double din stero it'll look out of place
    Jul 2009
    How about a black piece of construction paper with knobs and a radio drawn on it.
    '05 Magnum RT
    Parts left to buy-
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    Quote Originally Posted by jai_raider View Post
    as standard this car has a single din.....to install a double din you have to remove the heater vents....so even with a busted double din stereo it'll look out of place
    The important thing here is theft deterrent, not that it pass inspection. This might be enough:
    Quote Originally Posted by SpyderZ15 View Post
    Or you might be able to cover the area with a card bearing a photo of the OEM heater vents and radio -- just enough to fool the passing thief.
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
  1. Newbie Ideas
    By codyman in forum Newbie
    Last Post: 03-14-2005, 10:03 PM
  2. any ideas? 7.2 inch screen no TS
    By xdjxklusivex in forum Fabrication
    Last Post: 02-27-2005, 06:52 PM
  3. Custom Enclosure, Ideas Welcome
    By nsmoller in forum Fabrication
    Last Post: 02-02-2005, 12:21 PM
  4. CarPC Brainstorming Ideas
    By Bugbyte in forum General MP3Car Discussion
    Last Post: 12-27-2004, 02:40 PM
  5. Installation ideas
    By GingerPrince in forum General Hardware Discussion
    Last Post: 10-03-2004, 05:31 PM
