Results 1 to 5 of 5
Thread: Box Material
    Oct 2010
    Box Material
    Ok I have made a 5/8 mdf box for my 2 10" subs. I work at a wood shop and we have extra bambo material that is going in the fire. So I was wondering if it would be better to make my box out of 3/4 solid bambo wood or just stick with my 5/8 mdf box.
    If people dont know what bambo is, its a very hard wood, almost as hard as oak.
    Its not plywood or particle core, its solid bambo wood.
    Jan 2008
    i googled "why use mdf for subwoofer box?"
    and this was the first link:
    mdf is less resonant then other woods, which will allow for better sound..
    also, btw, this forum is primarily for installing computers in cars, so the audio specific advice is a little slim..
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    I think the bamboo might be an interesting alternative. Most bamboo that I've seen used in carpentry -- like flooring -- is made from thin strips laminated together. That would give the bamboo many of the same properties of MDF, which is a composite of sawdust and resin. It may be possible that -- because bamboo is very hard -- it could be closer to high density fiberboard, which is even more dense (and heavy) than MDF and is used in high-end applications.
    I think the bamboo might be worth a shot, and it would certainly give you some interesting bragging rights.
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at
    Jul 2009
    I say make it and compare it, then sell whichever you don't like.
    '05 Magnum RT
    CarPC coming soon. Hopefully end of 2010.
    Parts left to buy-
    Monitor, Bybyte frame, Axxess hook up, Sheet metal for double din case.
    Oct 2010
    thanks for the info guys, i think im going to do what you said, just make it and compare.
    and yea this is just bambo strips glued together, looks really nice, but if it sounds bad its as good as firewood.
  1. EPIA-M custon box
    By xpluis in forum Fabrication
    Last Post: 12-03-2006, 05:56 PM
  2. Noob question (capacitor and sub box)
    By greatkiller in forum Car Audio
    Last Post: 11-13-2006, 12:22 AM
  3. RSX Car computer in glove box
    By Zerach in forum Fabrication
    Last Post: 07-18-2005, 07:28 PM
  4. Wanting help with an ABC sub box
    By FyreDaug in forum Car Audio
    Last Post: 07-15-2005, 05:10 AM
  5. Wiring Distribution Fuse Box, cable length etc
    By Pabs in forum General Hardware Discussion
    Last Post: 09-06-2004, 05:59 PM
