Results 1 to 6 of 6
Thread: cut to size plastic
    Jan 2005
    Richmond, VA
    cut to size plastic
    Anyone know of a cheap online supplier that ships cut to size plastic? The only good one I've found is tapplastic.com, but I was wondering if there was any other cheap supplier.
    Jan 2008
    is there a reason you need it precut? i haven't looked in a while, but thought you could get bulk sheets pretty cheap when compared to them custom cutting it...
    Jan 2005
    Richmond, VA
    I just figured getting them laser cut is the closest cut you can get and its hassle free. I was thinking a small mini itx computer case from plexiglass for my car.
    Jul 2006
    I have to admit, I got a little chuckle out of a guy named "kasemodz" asking where to get pre-cut plastic. Having never tried to cut acrylic myself, I digress....
    Jan 2008
    it is a little funny
    i can't say i have ever seen the edge on laser cut plexi, so not sure on the end result, though i have cut lexan, and plexiglass, and neither are too bad-- lots of small bits flying everywhere, and if your looking for that glass edge, it can be tough-- it takes lots of sanding and plastic polishing to do(if this is what your looking for, double check with the company that has the laser cutter)..
    if you have a band saw, that seems to be the easiest way to get to start to get a professional looking cut, though i usually end up using my dremel with a 1-1/2" saw blade on it...
    Variable Bitrate djvillar's Avatar
    Sep 2006
    New York, New York
    if you're cutting plexi or acrylic and want to get a clear edge you can simply take a blow torch to it after cutting... You have it keep it moving or it will catch fire. Also where a fume mask. not just a dust mask. it will melt the sand/saw grooves smooth like the face.
  1. Plastic Welder - anyone used?
    By evandude in forum Fabrication
    Last Post: 11-15-2010, 11:55 AM
  2. HELP! Please post your LCD Panel Size and model info
    By Splash-X in forum LCD/Display
    Last Post: 01-24-2008, 08:23 AM
  3. How to cut out square hole on a plastic board?
    By ltx8d in forum General Hardware Discussion
    Last Post: 01-13-2008, 03:26 PM
  4. MCI error 261 and 263
    By genesis66 in forum Road Runner
    Last Post: 12-21-2007, 02:59 PM
  5. How to cut perfect rectangle in plastic plate?
    By Hark in forum Fabrication
    Last Post: 03-28-2006, 02:28 PM
