Results 11 to 20 of 21
Thread: Light Pipe - LED Effects - messing around
  1. #11
    Maximum Bitrate tempgp's Avatar
    Jun 2007
    New York
    EL Tape? like electrical tape or something else?
    I would drill a hole inside but diameeter of the rod is to close to my 5mm led rod is lie 6.8mm, i need to use frinds CNC to get the whole right in the midle then
    Acura / Honda A/V CarPC Adapter GA-NET+
    Centrafuse Garmin Mobile PC Skin - GMPC Rebellium Skin
    3D Tuning and Car Visualizer - Preview your car in 3D, change paint job and rims
  2. #12
    Jan 2008
    electroluminescent wire:
    one of the first results i found(very common for rc planes/helis for nighttime flying):
    http://www.glowire.com/plugplay.htm
    the problems that i have seen with el wire is that it is very dim during the day-- i have not seen any that is very bright(though i only tried one brand)
    when i originally did my headlight retro, i got some streetwires brand stuff, and it was barely visible in complete darkness..
  3. #13
    Jun 2009
    London, United Kingdom
    Thats the wire form, you can get strip.
    Heres a car covered in the stuff.... I mean covered! lol
    [media]http://www.youtube.com/watch?v=cOR9F1iaY04[/media]
  4. #14
    Jun 2007
    New York
    I like those glowing decals
    So that is some sort of electrical material attached to the body that emits light?
    Any links where i can buy that material? how thick it is?
  5. #15
    Jan 2008
  6. #16
    Jun 2009
    It's just like a vinyl sticker. The tape I'm suggesting is sticky on the lit side so you would fix it to the back of the acrylic tube allowing the like to shine through evenly.
  7. #17
    Jun 2007
    New York
    they look somewaht expansive
    Can I cut 1 pannel in many pannels?
  8. #18
    Jun 2009
    I believe so, I haven't personally used sheet just wire and tape. For your application tape is a cheap method to achieve what you're after.
  9. #19
    Jun 2007
    New York
    well im not really after anything just messing around
    i saw 5 feet 8mm wide tape on ebay for $6
    Probably will get it to play around.
    Site says i need 12V inverter.... what does inverter do? is it geting curent up like in florecent lamps? or its really just 12V adapter?
  10. #20
    Variable Bitrate djvillar's Avatar
    Sep 2006
    New York, New York
    Quote Originally Posted by tempgp View Post
    Use HVAC tape. Its literally tin foil with an adhesive side.
    I would drill a hole inside but diameeter of the rod is to close to my 5mm led rod is lie 6.8mm, i need to use frinds CNC to get the whole right in the midle then[/QUOTE]
    I've done it freehand. First use the thinnest bit you have, then go up to the desired mm. But of course if you have a drill press available... then yeah do that.
  1. How-To: Demon-Eye, Projector lighting
    By soundman98 in forum Fabrication
    Last Post: 06-05-2013, 08:22 AM
  2. LED Power light on the Lilliput....
    By Skipjacks in forum LCD/Display
    Last Post: 12-24-2004, 09:41 AM
  3. Voltage going through inverter switch?
    By CoCa in forum General Hardware Discussion
    Last Post: 03-29-2004, 10:57 PM
  4. Where can i find a lcd 20x4 with led back light
    By Dan in forum General Hardware Discussion
    Last Post: 04-28-2000, 01:14 PM
