Results 1 to 10 of 19
Thread: What filler do i use?
    Jan 2008
    i am working on making my taillights, and have gotten to the point that i need to fill in the gaps between the clear lens, and the tail housing.
    the gap is about a 1/8" and is about the same consistent size gap around both lenses
    on the back of the taillight, it says:
    L: PMMA
    B: PC+ABS
    so i believe that the rear housing part is ABS, and uses polycarbonate red lenses, but the front lens is a variation of plexiglass(even though it is a kiddy link, it describes it really well!)
    here is a pic of the housing i am working with, and a pic of how the project should look once it is done:
    before really looking at the lenses, i got a bondo-brand bumper repair kit, thinking that it was flexible enough to cope with the plastic parts, though i am starting to wonder if there is a better product out there for this..
    any ideas?
    VENDOR - Nexations Creations Nexson's Avatar
    May 2007
    After reading this a couple times over, i still don't know exactly what your asking , I would love to sugget something though, once I understand.
    Brian @Nexations Creations
    Specialist in Custom Interior Fiberglass OEM Replication Work.
    AIM: Exus28
    E-Mail: [email protected]
    Jan 2008
    sorry, i need to fill in the 1/8" gap between the clear outer lens, and the silver-coated plastic housing. the housing is ABS, and the outer lens is a variation of plexiglass.
    May 2007
    Okay, so in the picture, the clear lens has just not been removed yet? The lens will not be a part of the job? That's what is confusing me
    AIM: Exus28
    Jan 2008
    i was planning on keeping the clear lens, and just filling in the gap.
    the 3rd picture was done by a guy that works at his family-owned body shop-- he claimed that he used bondo to build up the lower plastic housing to the same level as the lens..
    i have plenty of bondo to repeat that part, but just think there is a easier way by using the existing lens as part of the build..
    a little more explanation--the second pic shows it the best.(the larger circle is complete, and the smaller circle has not been cut yet)
    the original layout for these lights is that the clear lens goes over the entire taillight. i am cutting out the section of the clear lens that is over the red domes.
    i need to fill in the gap between the outer-clear lens, and the base housing(silver part)..
    May 2007
    ahh
    I got cha,
    Are you able to remove the red light so it will be easier to fill and sand.
    I would recommend sandingiwht 60 grit before body filler
    get some evercoat fibertech body filler then some regular lite-weight filler to top it off.
    AIM: Exus28
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    I'm not sure that a standard body filler is your best choice based on you mentioning you think you are working with ABS, you might want to give some Evercoat Polyflex a try. I have a bottle here but I have not tried it yet. It is very expensive but I am told it is amazing stuff. This is primarily used to repair bumper shells with (I am told) great results.
    Here's a link to some info. By the way, friends don't let friends use Bondo, try some Rage Gold by Evercoat sometime, it will make you very happy
    http://www.evercoat.com/imgs/salesflyers/POLYFLEX.pdf
    May 2007
    It just a glaze, it won't build up like you need it to.
    AIM: Exus28
    Jan 2008
    thanks!!
    it sounds like a much better solution then bondo
    is there anything special i should know, or does it apply/smell like bondo?(i kind of expect it to smell similar, but if i could do most of the work in my basement, it would make everything easier..)
    Jan 2008
    i am kind of new to the professional approach to parts work like this.. what light wheight filler do you recommend?
    i have heard of rage gold-- mostly from car audio how-to's on building a fiberglass box, but never used it.. would that be a good light weight filler?
    Quote Originally Posted by paulf
    after reading the description of the polyflex i am not so convinced that it is meant for this, as i will have at least a 1/8" of standard filler there--
    Poly-Flex™
    A flexible polyester glazing putty designed for spot filling and skim coating over repair areas on flexible bumpers and plastic parts. Its flowable viscosity is ideal for filling minor imperfections such as sand scratches, nicks, dings and gouges. Poly-Flex™ may also be used to skim coat over repair areas or large surface areas that have the original paint still intact. Blue cream hardener included.
    it seems like it is meant for very minor imperfections, where i will have more major imperfections
    i am ready to order now, just need to know what i need!
  1. Bondo-Glass or Normal Bondo Body Filler
    By adambeverage in forum Fabrication
    Last Post: 04-04-2010, 12:44 AM
  2. All about Bondo
    By ssteger in forum VaultWiki
    Last Post: 02-11-2010, 01:16 PM
  3. Body Filler
    Last Post: 10-19-2009, 04:17 PM
  4. filler for fiberglass
    By pjoseph in forum Fabrication
    Last Post: 07-23-2009, 12:46 AM
  5. What filler to use?
    By Meelobee in forum Fabrication
    Last Post: 10-27-2005, 01:53 AM
