Results 1 to 6 of 6
Thread: abs welders..
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    abs welders..
    i know turbocad uses a soldering iron type plastic welder but i've seen a few, less expensive air welders. do any of you have any experience with these? how do they compare?
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Maximum Bitrate david69leonard's Avatar
    Oct 2006
    Texas
    I have a soldering iron type with a feed tube and an air welder, I prefer the "soldering iron" because i can smooth out the surface of the two pieces with the tip of it, less sanding involved. The air gun pretty much just melts the pieces so you can paste them together, you can use rods with both, but the speed tip (soldering iron) works best because it is more precise... If you combine the speed tip with a standard heat gun it is possible to mold the ABS into what ever shape you desire... A good way to make parts i have found is by fabricating a solid structure out of plaster or wood, then heating up the ABS with a heat gun allowing it to form over your solid structure, then using the speed tip to correct imperfections and piece it together. Make sense at all? Hope i could help.
    Low Bitrate RonsRed88's Avatar
    Aug 2009
    Western Washington State
    Here's my advice regarding hot air plastic welders...DON'T DO IT! That's just my experience. They melt and warp too broad an area for working on a bezel. Use the soldering iron type instead. Here's a link to the experience I had in my worklog.
    Good luck,
    Ron
    Feb 2011
    I have the nicer Harbor Freight plastic welder that is about $70 and I use it to make custom PVC cold air intakes for a a lot of rides and it works great. I also do a lot of single DIN to double DIN conversions and normally use glue and lexan to fill in my gaps. I tried to use my plastic welder once and that almost didn't work out for me. I have went back to using glue and clamps ever since.
    However, the soldering iron sounds like it would work better.
    thekl0wn's Avatar
    Apr 2005
    PoCo, Indiana
    From the people I've talked to at a local plastics fabrication place, the hot air welders aren't really designed to work with the thin/small areas like a bezel. It's pretty much the same as with welding... It would be like cranking the amperage way up on an industrial unit, and trying to tack weld body panels... You're just going to blow holes, warp, and FUBAR everything around. For an aesthetic application like bezel modifications, the soldering iron style is perfect.
    Play with it, 'til it's broke.
    Feb 2011
    And that was exactly what happened when I tried to use mine on a bezel. It warped it.
