Results 1 to 10 of 12
Thread: Which way to go...
    Sep 2008
    Which way to go...
    I've trimmed my Lilliput bezel to fit. There is unfortunately an area either side of the bezel that needs to be filled. So I'm toying with two ideas. A. Incorporating the bezel into the radio fascia or B. Mounting the bezel to the dashboard and filling the fascia. My questions is, how do I fill that small area either side? The plastic is fairly thick and I doubt I'd be able to find something similar in hardware shops.
    VENDOR - Nexations Creations Nexson's Avatar
    May 2007
    Just send it to me and I will finish it for $150.
    If you don't use the correct materials, then it will just crack.
    Brian @Nexations Creations
    Specialist in Custom Interior Fiberglass OEM Replication Work.
    AIM: Exus28
    E-Mail: [email protected]
    Jan 2008
    nexson's looking for work!!
    this is similar(some processes/materials may be different) to what you would need to do, or what nexson would do:
    http://faq.ninja250.org/wiki/Plastic...ith_ABS_cement
    beware, it is a time consuming process...
    Oct 2009
    Jerrabomberra, NSW, Australia
    Send it ti Nexson, his work is first rate. This way you can concentrate on the rest of the install.
    May 2007
    Thanks for the support guys!
    This is too easy let go. I tend to stay away from the technical jobs lol.
    AIM: Exus28
    Sep 2008
    Quote Originally Posted by Nexson View Post
    I've read a few posts regarding cracking. Do it once, do it right! Unfortunately $150 what it would cost me to send.
    Quote Originally Posted by soundman98 View Post
    this is similar to what you would need to do, or what nexson would do, beware, it is a time consuming process...
    Been looking at Plastex on Youtube. Not available down here that I can find.
    Quote Originally Posted by FXST01 View Post
    Rest of the install is all but done. Wires are all in. PC is in the boot and removable. Just want the fascia to be right and as we all know, that's what we are looking at all the time, it has to be right.
    Thanks for the suggestions. I'm going to mount the screen bezel to the dash. Then I'll make the hole in the fascia and have the two separate.
    Oct 2009
    Good luck and don't forget the photos.
    May 2007
    Where are you located?
    AIM: Exus28
    Jun 2010
    Vancouver, Washington, United States
    What kind of plastic is it? If it is ABS, you can make a paste using ABS scrap & M.E.K. It's not the easiest method, but it will make a permanent, non-cracking filler for those gaps. There is a thread here about liquid ABS that may be worth a read. If it is PPE or PE, then there is no solvent that will melt it
    Sep 2008
    Far North Queensland, Australia.
    Quote Originally Posted by Ryven View Post
    It's a mixture of materials. I think I'll finish the install, leave the fascia until last. Spent a couple of hours today trying to get the bezel at the right height and centred.
