I used polycarbonate sheeting for a high voltage (30KV) outdoor project. It does not weaken or breakdown under intense sunlight.
I found it very easy to shape with a heat gun and work with.
I'm fabricating a windshield mount for my iphone so I can use GPS, take HD video while offroading, have music and have my klinometer viewable. It is based on an otterbox case, which uses a separate holster piece - this is what the mount will be built off of - the phone and case will pop into. Anyway, I contacted otterbox and they informed me the holster is polycarbonate (was hoping they'd say ABS!). Anyway, how will polycarb react to acetone? I was really hoping to make the rest of my mount out of various pieces of ABS pipe/fittings molded together. But idk now... is there anyway to get a chemical bond between ABS and polycarb? If not, can I plastic-weld/heat-mold polycarb (as in make a wood mold and heat shape a sheet of polycarb over it)?
---------- Post added at 02:04 PM ---------- Previous post was at 12:57 PM ----------
I finally searched google enough to find my answer - that I can dissolve/glue polycarb with acetone. Still not sure about using it with ABS but I think I'll pass and buy a polycarb sheet to form. If anyone else has more info or personal experience on this though, I'd be happy to hear it!
GA-Z77N-WIFI, i5-2400S, 8GB, Intel 520 128GB SSD, M4-ATX Modified, 2 Rev Cams, 2 Web Cams
8" 16:9 TRANSFLECTIVE, Win8-64, Dual GPS RX and Garmin PC + Odyssey Nav, FM-DAB+, BB-Rec
T-Screen HVAC control, custom microcontrollers, code and FE. CarPC Project
Thanks, this is perfect considering this mount will be affixed to the windshield with a rear view mirror mount and will be in direct sunlight! Any issues with painting polycarb? I was thinking Krylon Fusion should work great.
after some bad experiences with very smooth plastic, i always try to rough the plastic up a little to promote good adhesion(nexson would probably say to use something like 200grit, i don't like to go below 800-1,000)
My 2001 Mitsubishi Eclipse GT:
"The Project That Never Ends"
more projects then time!
Led Skyline Tail Lights--100%
High Power Led Reverse Lights--100%
Led third brake light--100%
Led front turn signals--0%
HID retro--100%
oh yeah, I'd for sure rough it up a bit but thanks for throwing that out there!
Another question, I'm gonna drape form this into a three dimensional shape, over a wooden form with a heat gun; basically something the size and shape of a box of cards with one of the large faces open. I'l'l need to fill in the seems... can I use shavings of leftover polycarb and acetone to make sludge like I would with ABS?
