Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Fabricating Dashboard
    May 2010
    Herákleion, Iraklion, Greece, Greece
    Hey guys. So my dashboard kind of sucks for customization, since its all one part, and its very hard to make a panel only for the LCD or osmething like that.. so i am thinking of re-building it, or at least change some of it. But the thing is its of quite good materials (car model audi 80) and i dont wotn to replace it for something like fiberglass (solid as crap:P)
    So i was wandering if some1 has any idea of matarials i could use to make the surface a bit soofter or something like this. i still think that for the main frame i will go with fiber, to make it hard and strong, and then cover it with soemthing else..
    any ideas are apriciated!!
    VENDOR - Nexations Creations Nexson's Avatar
    May 2007
    Post some pictures of your dash!
    Brian @Nexations Creations
    Specialist in Custom Interior Fiberglass OEM Replication Work.
    AIM: Exus28
    E-Mail: [email protected]
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    Is this one?
    May 2010
    yiap. exactly this one. only the wheel is on the other side:> i am thinkiing of getting one from a scrap yard, and modifying that one.. but with lots of cutting.. to make something like BMW style:>
    Jan 2009
    Naples, Floridaaaaaaa
    Lots of angles....if you want to follow those lines, you could make a metal (aluminum frame), foam and vinyl or leather finish.
    The low budget model ! 2005 F-150
    • -Custom fiberglass console, CB,Interfaced OBDII
    • -In-dash multimedia w/ bluetooth
    • -Piconet PAN & Wifi Edge internet
    • -Advantech relay board, Pololu microcontrollers w/servos
    • -Embedded Axim palmtop w/backup GPS
    May 2010
    i was thinking of making the frame with polyerethane and fibergalss and then finishing it with something.. .what is vionyl and foam?? cause i dont know very much from those... i want to make something like that pic. or, almost :P
    Variable Bitrate djvillar's Avatar
    Sep 2006
    New York, New York
    Check this place out. I've gotten some faux leather from them. Good products. Here's a link to the foam you'll need, you're finish cloth/vinyl/leather will go on top of this:
    yourautotrim
    May 2010
    o thans dude! i thin of going with blac leather wherever theres gray leather in the above pic, and with raw fiberglass, or some other plastic finish (like the foam you sendeD) whereever its white, bu painted black. also i found out that if you paint one side of plexiglass black, the other side is a frikingg blac mirror:> so i will be using that instead of the wood:>
    well, thats the main idea at least. all that has to be in peace with the car:>
    Jun 2010
    Vancouver, Washington, United States
    Take lots of pictures during this build. This could end up being a very popular thread! Everyone loves good, custom work.
    -Zack
    via Droid Charge
    May 2010
    well, i am having exams period this month, so i will just gather information and make in my mind how it must be done. from the enxt month i will go on with buing the metarials. i want to buy from a scrap yard a diferent dashboard and do the work on that, i case i fail:> i also was thinking of making the logo of audi, with somekind of luminus cable, and puting it behind black plexiglas in the midle of the dashboard, so it lights up when my roadlights are on. but i dont want it to be to shiny cause it would suck:P what you guys think about that?
  1. Need Help fabricating enclosure.
    By MastaShake in forum Fabrication
    Last Post: 08-22-2007, 04:23 AM
  2. My 98 GS-T Fabricating Thread!
    By 97GST in forum Fabrication
    Last Post: 06-12-2006, 02:26 AM
  3. my first time fabricating need a little help
    By Magsino in forum Fabrication
    Last Post: 11-29-2004, 01:48 PM
  4. fabricating din housings
    By zojirushi in forum Newbie
    Last Post: 10-21-2004, 07:16 AM
  5. fabricating dash
    By acetaminophen in forum Newbie
    Last Post: 11-20-2003, 12:09 AM
