Results 1 to 6 of 6
Thread: Making factory dash bezel...
    Mar 2009
    I am trying to add a 15.4" touchscreen to my 2000 Silverado and have gotten this far following turbocad's stick thread. My question is, do I need to put another layer of the Dynatron stuff or do I start with the second part? Do I need to sand down what I currently have? Here is the photo album:
    http://imageshack.us/g/202/img01241h.jpg/
    Jan 2008
    sand it down to the approximate shape you want, and if there are low spots, make a mental note of them, and after sanding most of the part, apply the filler again... and repeat until the shape is very close to what you need..
    Mar 2009
    Do I fill in with the Dynatron stuff or the other 3m stuff? Also, what sandpaper do I use? 30-grit and then 100-grit?
    Jan 2008
    use the 30grit to get the piece to the shape you need. i believe yuo will need to use the dynatron stuff.
    Mar 2009
    When do I use the 100 grit and the other 3m stuff?
    Jan 2008
    once you have the rough shape, and need to smooth everything.
  1. how to: make a factory bezel
    By turbocad6 in forum Fabrication
    Last Post: 03-09-2013, 03:18 PM
  2. making bezel for 2003-2007 Caravans
    By sgtarky in forum Fabrication
    Last Post: 11-18-2010, 04:09 PM
  3. how to simulate factory gray vinyl on dash?
    By liquid30 in forum Fabrication
    Last Post: 04-23-2008, 11:13 PM
  4. Replies: 11
    Last Post: 11-03-2006, 10:21 PM
  5. custom dash making....
    By ifnh573 in forum General MP3Car Discussion
    Last Post: 10-13-2001, 01:39 AM
