Results 1 to 10 of 12
Thread: 1994 holden statesman touch screen ideas
    Sep 2011
    Cairns, Aus
    hey just thought i'd post a quick pic, see if anyone had any tips for me...
    i've bought the screen but I want to make it look as OEM as possible... im going to move the abs/irs part to the bottom to take up that space and my screen with fill the space above it within 5mm r so gap... the climate control will stay where it is...
    heres a pic of what it looks like now, any ideas would be awesome
    Cheers,
    Tom
    Name:  Statesman interior.jpg
    Jan 2008
    i think the best suggestion would be to follow the sticky at the top of this section. you already have a good game plan, which is usually half the battle.
    Jul 2011
    Sydney Australia
    Had same idea(vp calais) and it is a good option. However i choose not to do it. Instead i fitted the screen just above stereo and just below air vents. i did this as i wanted to keep everything original and the touch screen 8" within easy reach and view. Your idea is good for the OEM effect and will work well. Here's a vid of the screen set up in my vehicle if your interested.
    Sep 2011
    Cairns, Aus
    ... Nice setup!!
    I did think about just a single din touch screen, but as i will probably sell the car with the car pc included i thought i may aswell integrate it...
    finding the screen was the hard bit, as you would know, there is **** all room behind the stereo, even hard to fit wires behind standard head unit...
    screen arrives on monday so i guess i will figure out if its going to work then
    Raw Wave
    Nov 2009
    Let me know if you want to dispose of your current Alpine front panel...
    Jul 2011
    Sydney Australia
    Fantastic! look forward to seeing the finished project. Ya right. Bugger all room behind head unit and i think that was the hardest part of the install was getting the head unit back in without pinching cables.
    Newbie theBlueLight's Avatar
    Aug 2008
    Melbourne, Australia
    A couple of days ago I suggested doing exactly the same thing to my girlfriends VS, which has a similar layout. She forbade me. Which is probably just as well, the main problem that I could foresee is that the screen would be very low down on the dash, so the eyes would have to travel a much longer distance than if the screen was mounted, for example, where the air-vents above the head unit are. If you were planning on running a GPS this could be too distracting while driving, probably more dangerous.
    Just my thoughts. Would you be willing to relocate the air-vents as an alternative?
    Sep 2011
    Cairns, Aus
    Screen to low
    i have thought about this, but i live in cairns, if you need a gps then you have some serious problems... most of the setup will be for wank factor more then anything/passenger can watch movies/surf internet on long trips....
    The screen arrived today and its a little smaller then i thought, so now that i have a little space, i am thinking of mounting the screen on a tilting bracket so i can tilt it up towards me...
    guess this weekend will test my fabrication skills out...
    Sep 2011
    Cairns, Aus
    Alright so I've installed the screen temporarily into the car to test its operation and so on...
    made some brackets up and after a fair bit of swearing managed to get it set in solid... cables will obviously be behind the dash and when i finish and i will get a black surround made up to fit perfectly around the screen, cardboard is the template...
    Name:  2011-09-24 12.47.56.jpg
Size:  51.5 KBName:  2011-09-24 12.47.51.jpg
Size:  51.7 KBName:  2011-09-24 12.48.16.jpg
Size:  51.1 KBName:  2011-09-22 21.35.43.jpg
Size:  33.9 KBName:  2011-09-24 11.04.37.jpg
Size:  53.8 KBName:  2011-09-22 21.33.19.jpg
Size:  34.1 KBName:  2011-09-24 12.50.36.jpg
Size:  41.1 KBName:  2011-09-24 12.39.52.jpg
Size:  52.7 KBName:  2011-09-24 11.04.25.jpg
Size:  46.6 KBName:  2011-09-24 11.05.31.jpg
Size:  44.4 KBName:  2011-09-24 12.53.59.jpg
Size:  51.9 KBName:  2011-09-24 11.50.25.jpg
Size:  46.2 KBName:  2011-09-24 11.04.52.jpg
    Jul 2011
    Sydney Australia
    Lookin good! Will be a nice oem look when you have your black surround made and fitted. What you doing with cd head unit? Or are you having a straight to amp set up?
  1. Holden WL / VZ Caprice GENIII LS1 - Slow Build Follow - Some Tech Info
    By mayhembdm666 in forum General MP3Car Discussion
    Last Post: 04-22-2012, 04:38 PM
  2. Replies: 2
    Last Post: 09-30-2011, 11:06 PM
  3. Replies: 0
    Last Post: 06-11-2010, 11:02 AM
  4. 7" touch screen detachable display? any ideas?
    By seventynine in forum LCD/Display
    Last Post: 11-25-2007, 05:07 PM
  5. Replies: 9
    Last Post: 10-04-2007, 02:52 PM
