Yeah, that's def air pockets. Get those bags of brushes from home depot
brushes from home depot. A trick I picked up, cut them down so the bristles are only 1" long. This makes makes sure the you're not holding a ton of
resin in the brush. Also it s makes it easier to stipple of matte.
As for the nylon, if you want to add strength, you should be using thick cord (like 1/2"). The trick to not getting air bubbles is, mix and put on one coat of resin, that's it. Wait for it to become tacky. If you press a dry piece of matte against it, it should stick. This will also make putting the first layer of matte on, because you can lay in all on first then just stiple in the resin till saturated. Also, don't put full, in tack pieces over the rope or sharp edge. It stead, chop up that matte and place the serrated edges there so that the strands conform around the sharp turn.
