Results 1 to 10 of 19
Thread: Quck question on working with fiberglass
    Maximum Bitrate nasa's Avatar
    Aug 2006
    PA
    Hi,
    I am creating a sub box for my accord and have progressed pretty far with it... However, I have noticed that I have a lot of "air pockets"/"air bubbles" -- or that is what I think they are. Essentially, they are areas of white amongst my brownish mold. Most of the spots are hard to the touch (ie: don't flex with the thumb test). Some are actually separated from the mold. The mold has 4 - 5 layers of matting on it and for the most part feels pretty strong, although I haven't gotten brave enough to do the body weight test on it yet. And there are some areas that are still *tacky* -- it's below 50 here so curing has been slow, even when adding more hardener. So, all that said, what needs to be repaired and what doesn't? And for the items that need repair, how do I go about fixing them? Thanks in advance,
    Nasa
    Nov 2011
    Heres what I would do... But it depends on the bubble type in my opinion.
    1. Big bubbles that protrude from the acutal mold, I would hit with a knife, dremel, or grinder and rebuild the area.
    2. Big bubbles that don't protrude from the mold, i would drill a hole and brush some resin in the to fill the void.
    With the larger bubbles I would toss another layer or 2 of glass over the bubbles with 2" over lap if possible.
    Smaller bubbles that protrude you can probably leave from a structral point of view and the even smaller bubbles that are in the layers don't even worry about those.
    A 1/16" layer of fiberglass can bridge a 1" hole and with hold approximately 80psi. 1/16" layer is roughly 1 layer of 1.5oz chopped strand mat. 2 layers at roughly 110mils will take 100psi over a 1" hole. So from a structral point of view the bubbles don't truely matter too much. However I don't think you want your sub box to flex at all, especially if you are going to paint it.
    Hope this helps.
    Mike
    Variable Bitrate djvillar's Avatar
    Sep 2006
    New York, New York
    Upload pics. Not sure what you're talking about. You are working from a "mold" , so you're making a positive from a negative? Doesn't matter really just want to clarify. Not really sure how you'd fix it other then to drill in to expose it then fill in with resin, but really the issue is why its happening in the first place.
    It happened to me the first couple of times working with resin. It usually means your trying to work with it too long, its starting to cure and your still trying to spread it on the glass. What happens here, is that the surface of the glass gets resin, but its not viscous enough to saturate through the surface. This is not good, especially for a sub box that will be under a lot of flex. Don't put more catalyst. or if you do, have MEK or Acetone around. In addition to the 2 parts, dump some of this in there. It will increase the work time by not allowing the catalyst to react until the MEK/Acetone has evaporated. And as soon as it starts getting hard... stop using it. Make a new batch.
    If you use either, especially MEK, where a fume mask in a well ventilated space. NOT KIDDING, its harmful to breath in. And to help curing, getting a space heater on that thing with a vent pulling fumes outside.
    Happy New Year!!!
    Aug 2006
    PA
    Thanks djvillar,
    I will post some pictures tomorrow, as it still puts off some fumes so I can't bring it into the house. I am working on it in my backyard (cause it was to strong in the garage which is attached to the house). I think my biggest problem is the cold, the resin was thick right from the can -- I have started to warm it up prior to using and the weather is also being a bit more helpful.
    The other issue I have been running into is around some curves, where the matting isn't forming the way I would hope. The prime example of that is around some nylon rope I added for strength (a little googling can be a dangerous thing). I couldn't for the life of me get the mess to stick around the rope -- even though I had soaked the rope with resin prior to putting it down.
    Oh, I am referring to the popped out form from my trunk as the mold. If you look at my accord thread here: http://www.mp3car.com/worklogs/11769...ml#post1465342 you'll see what I am referring too.
    Thanks again,
    Aug 2006
    PA
    So I lied... Here's some example pics (see my thread to put them somewhat in context),
    This shows the area around one of the threads...
    Lots and lots of *white* most of which is hard (can't flex with my thumb). Comments?
    FLAC SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    When you applied the matting did you pat it down with a paint brush soaked in resin. We used steel rollers and brushes to make sure the layers of matting had no air pockets. You could just try and soak those areas with more mixed resin. SNO
    Aug 2006
    PA
    SNOtwistR,
    Yeah, I have been trying to apply the dab the mattng with a wet paint brush this whole 1st attempt. I think I am getting better at, but then again... When you suggest soaking the areas with more resin, do I need to drill/cut open the areas to let the resin in (I'm guessing that's the case)?
    Nov 2009
    Keswick,On Canada
    prolly a good idea to open up the area abit to get resin under the air pockets and even on top of the matting to hopefully soak in. Very good for first attempt! SNO
    Aug 2006
    PA
    So,
    Mike posted the following, which for some reson hasn't show up here -- and it good stuff...
    A 1/16" layer of fiberglass can bridge a 1" hole and with hold approximately 80psi. 1/16" layer is roughly 1 layer of 1.5oz chopped strand mat. 2 layer of at roughly 110mils will take 100psi over a 1" hole. So from a structral point of view the bubbles don't truely matter too much. However I don't think you don't want your sub box to flex at all, especially if you are going to paint it.
    Hope this helps.
    Mike
    Thanks Mike
    Sep 2006
    New York, New York
    Yeah, that's def air pockets. Get those bags of brushes from home depot brushes from home depot. A trick I picked up, cut them down so the bristles are only 1" long. This makes makes sure the you're not holding a ton of resin in the brush. Also it s makes it easier to stipple of matte.
    As for the nylon, if you want to add strength, you should be using thick cord (like 1/2"). The trick to not getting air bubbles is, mix and put on one coat of resin, that's it. Wait for it to become tacky. If you press a dry piece of matte against it, it should stick. This will also make putting the first layer of matte on, because you can lay in all on first then just stiple in the resin till saturated. Also, don't put full, in tack pieces over the rope or sharp edge. It stead, chop up that matte and place the serrated edges there so that the strands conform around the sharp turn.
  1. Question about fiberglass over a foamcore mold
    By replicant in forum Fabrication
    Last Post: 10-30-2007, 02:00 AM
  2. fiberglass box question
    By BoondockSaints in forum Fabrication
    Last Post: 07-26-2007, 12:30 AM
  3. Fiberglass Curing Question
    By Curry in forum Fabrication
    Last Post: 08-28-2006, 08:11 PM
  4. We have quck reply back!
    By thanatos106 in forum Off Topic
    Last Post: 10-19-2005, 05:01 PM
  5. another fiberglass question
    By chris102984 in forum Fabrication
    Last Post: 09-08-2005, 11:13 PM
