Results 1 to 3 of 3
Thread: vertical lift lcd screen
    Feb 2012
    North Chicago, Illinois, United States
    This will be my first stab at building a more integrated car pc, and will be aiming for the entire setup to be more or less invisible when the system is off. To that end I am planning on having the screen hidden in the dash when not in use, and lifting up when system is powered on. Does anyone know if the commonly used screens are light enough that a cd drive would be able to accomplish this?
    Jan 2008
    hmm, i don't think so. but if you rigged something using pulley's and string, it might work..
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by 78trans am View Post
    i doubt it and i dont think they would have enough travel. yould be better off with a lead screw and motor or an actuator.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  1. Spring loaded tilt lift screen support...Help needed!
    By RipplingHurst in forum Fabrication
    Last Post: 12-11-2010, 06:04 PM
  2. Vertical lines on screen
    By fatejd in forum LCD/Display
    Last Post: 06-11-2009, 11:28 AM
  3. Replies: 1
    Last Post: 10-12-2008, 06:42 PM
  4. Homebrew motorized screen lift
    By Lebult in forum Hardware Development
    Last Post: 02-10-2007, 01:04 PM
  5. Vertical colored lines on screen?? HELP
    By AlphaFox in forum LCD/Display
    Last Post: 10-21-2003, 09:06 PM
