Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: DIY steering wheel remote for cars that dosent have.
  1. #11
    May 2010
    Herákleion, Iraklion, Greece, Greece
    mainly cause i dont know how to hook it on the computer but there is more.. i dont really like their look and they can sometimes give you hard times when driving...
  2. #12
    Apr 2012
    VA
    Quote Originally Posted by Quaraxkad View Post
    Why not use a wireless remote?
    Attachment 66097
    That would look SUPPPPPER whack on a car that has a custom computer, Amp's, Subwoofers, Custom paint/doors/dash/Leather and new carpet.
    Imagine that your car is so pimped out. Then you get the idea for easy access using your Steering wheel. Well your whole car is boss and you are going for a clean, modern, and sleek feel. Having a Gray snap on remote that costs like 10$ from china is not going to do it. This tutorial is a little to basic considering the final result is not the best but the idea is awesome.
    Sand your steering wheel more by the way lol.
  3. #13
    May 2010
    lol thanks will do when i have the time
  4. #14
    Newbie BennY-'s Avatar
    Jan 2006
    Germany, Cologne
    don't like!
    i would prefer something like the attached image of an seat ibiza radio remote, it's attached behind the steering wheel, and should look more OEM
  5. #15
    May 2010
    what part of the " i cant pass cables through my steering wheel" you failed to understand ? If i used something BEHIND the steering wheel, then it would be as "disturbing" as using the touch screen instead... whats the point?? although it could be a good addition to the steering wheel buttons, for some less used functions.
  6. #16
    Mar 2006
    ^^^ you can awlays pass wire from the wheel to the/down the shaft....you just havent figured out how to do it yet...
  7. #17
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    settra, do a search for 'slip ring' this is how OEM steering wheel buttons passwires through the steering wheel.
    Or maybe you can get a later model Audi's steering wheel which will fir your car and use the buttons on that.
    That is what I did with my BMW E36
  8. #18
    Jun 2010
    Vancouver, Washington, United States
    Enforcer, wouldn't a new wheel require a cable reel be installed? I'm guessing that is what the slip ring is. I've not installed my new wheel and am unsure where exactly the cable reel sits. I just know how they work and I see in all my electrical diagrams that anything going to the steering wheel just says "cable reel"
  9. #19
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    The 'cable reel' is really the 'slip ring' or 'clock spring'. It usually fits to the back of the steering wheel and plugs into it.
    Basically it is a flat cable that is rolled up into a spring.
    There are three main things to be concerned about retrofitting a newer Steering Wheel.
    1. the actual fit to the sterring wheel stalk. - Using a steering wheel from the same Car Maker usually gurantees this but you still need to check.
    2. Airbag fitment and trigger - If your car does not already have an airbag, then this is not a worry.
    3. Will the new steering wheel and it's 'cable reel' (clock spring/ slip ring) fit and connect OK with the stalks.
    4. Decoding the signals from the buttons once you have connected them through the cable reel.
    Have a look at the thread I linked to in my above post, there are a number of pictures that show the steps I went through.
  1. After-mounted steering wheel remote
    By Aze in forum Show off your project
    Last Post: 08-16-2009, 05:56 PM
  2. Steering Wheel Remote Control
    By drdave in forum Car Audio
    Last Post: 02-21-2008, 11:48 PM
  3. Steering Wheel Remote Control
    Last Post: 02-17-2008, 02:39 PM
  4. steering wheel remote
    By DaJ0Pe in forum Input Devices
    Last Post: 06-19-2006, 03:07 PM
  5. Steering wheel remote controls...
    By zummi in forum Input Devices
    Last Post: 07-19-2004, 02:38 PM
