As far as the controls go type of control go you have to verify if you have automatic climate control or not.
If you are thinking of using the digital versions on the 03 - 05, you're out of luck.
It has never been done and it never will because the work involved is just too much.
I have done the research and I'll tell you this. The whole computer data bus for both systems are completely different. Not only will the wires not match but the whole
wiring harness is different and the color coding is not the same.
In addition you will need to reprogram the car's different BCMs and a whole lot more. It is definitely not worth the amount of work involved.
