The old bezel should have the snap into place pins. use plastic weld to glue new plastic pins onto the new bezel using the old original one as a guide to glue them into the proper position(be sure the pins are the same diameter as the ones on the original)...then let the the glue dry and cure for a day. The bezel should snap into place like the original
If they are the type that require screws...the same method applies, just be sure that they are plastic!!
LinkBack URL
About LinkBacks
