Results 1 to 4 of 4
Thread: Fabrication of new Bezel using 3-d printer..
    May 2012
    Grandville, MI
    I am looking at the possibility of making a dash bezel for my (yet to be purchased) 10" screen to fit it into my console in my truck. The current console is square and has a couple pockets. I am going to remove this trim piece, scan it in to my computer. (I am told there is software available with a kinect to do this.)
    I plan to make the necessary adjustments to the file created and then print out a model and see how it looks.
    The 3-d printer is something I would have access to because of a local Maker group.
    I am curious about the materials that it uses. They told me the plastic it "writes" with melts at about 500F and I wonder if that will be an issue. I have also been considering coating it in fiberglass but figure this might melt the stuff.
    Does anyone have any experience with this stuff? I am told they can use Acrylic but that stuff gives off toxic fumes.
    Thanks!
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    some printers can use abs. if you can use that, it's your best bet if you need to modify it at all (grafting it into a larger piece or whatever) but as far as 500f melting point... unless you live in hawaii... and plan on driving into an active volcano. i can't see the bezel ever hitting those temps
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    May 2012
    Grandville, MI
    This unit will do ABS but they told me it off gases nasty vapors and gives everyone in the building headaches. Needs to be in a vent hood or something.
    Rodney
    Dec 2004
    Los Angeles Ca
    you'll probably be just fine with the other material to be honest. if your fg is getting that hot, something is really wrong. i warn against coating in fg without prepping that surface to allow the fg to 'bite' into it. I use a fg/plastic combo on the very first mod i did... 9-10 years ago on my rx7. and it quickly showed stress cracks
    M10k
    My Car Pc Install
    My Boat Pc worklog
  1. First time bezel Fabrication
    By VmtSquad in forum Fabrication
    Last Post: 11-11-2009, 05:56 PM
  2. VW MKV Bezel Fabrication/Machining
    By sux89 in forum Fabrication
    Last Post: 02-13-2009, 02:14 PM
  3. My 1st bezel fabrication for E39
    By BCN in forum Fabrication
    Last Post: 11-18-2006, 04:23 AM
  4. 98 Accord with Xenarc 700TSV bezel fabrication
    By Dracord in forum Fabrication
    Last Post: 02-07-2006, 12:35 PM
  5. Bezel fabrication
    By greenwire in forum Fabrication
    Last Post: 04-18-2005, 05:13 PM
