Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Like Tree1Likes
Thread: is epoxy ok to use on abs when building bezel?
  1. #11
    May 2010
    Herákleion, Iraklion, Greece, Greece
    if you are good at sanding, then i would do the following. (rememeber, with acetone and abs, they will become ONE, if you later apply force, it will brake elswhere:P ),
    use some aluminium foil, on the back side of your bezel, to make a panel , for the new abs "to sit on" . then soak your bazzel with allot of acetone , and then apply your abs. bear in mind, than when you will apply the second hand, the first one will ALSO melt. so try to make it as thick as possible!
  2. #12
    Jul 2009
    Just an updated photo, its coming along.
    Sent from my SCH-I545 using Tapatalk 2
  3. #13
    Jul 2009
  4. #14
    May 2010
    cool. very nice!
  1. Epoxy for PLexiglass
    By HummDinger in forum Fabrication
    Last Post: 06-08-2012, 03:00 PM
  2. Plastic Epoxy
    By 4ofakind in forum Fabrication
    Last Post: 04-15-2011, 04:32 PM
  3. Replies: 58
    Last Post: 05-14-2009, 10:21 AM
  4. Epoxy
    By johnnyaction314 in forum Fabrication
    Last Post: 06-11-2007, 01:08 PM
  5. Replies: 26
    Last Post: 10-05-2006, 06:29 PM
