Results 1 to 3 of 3
Thread: Fiberglass help/ideas
    Apr 2014
    looking for a little guidance, can I fill the side pockets fullish of resin? i want the amp to be on an angle back twords the window and run my wires into the fender. tips/ideas/suggestions? this will be my first fiberglass install..... I bought the sub box off of somebody.....
    thanks in advance!!Name:  photo 3.jpg
Size:  67.4 KBName:  photo 1.jpg
Size:  128.1 KBName:  photo 4.jpg
Size:  60.1 KBName:  photo 2.jpg
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    Resin doesn't have much strength to it without cloth, I would suggest you glass it properly with a cloth resin mix (kitty hair) or stretch it with cloth and lay it up. Some people bond glass to ABS while laying it up by drilling holes in the abs so the resin can drip through and form a mechanical bond. Others prefer to bond a separate fab'd glass piece with 3M Duramix 40/40 or plastic epoxy. There are several ways to skin the cat with varying results. You could also tape it off, lay up the amp base, pull it and then use screws etc to mount it to the ABS piece. Remember if an amp is hanging off it while going over the bumps, some decent strength on whatever you do will be needed.
    Dec 2004
    I would pull that whole panel, trim off what's in red. It appears the blue piece will lift out - if it does I would foam that up and shape it. Once done I would hit it all with 80grit and then a few layers of your choice of fiberglass n top.
  1. Fiberglass ABS
    By zerocover in forum Fabrication
    Last Post: 06-15-2006, 02:57 PM
  2. New to Fiberglass!
    By mjking816 in forum Fabrication
    Last Post: 12-18-2004, 04:58 PM
  3. Replies: 11
    Last Post: 04-27-2004, 08:43 PM
  4. fiberglass
    By mp3z24 in forum General MP3Car Discussion
    Last Post: 01-25-2002, 05:29 PM
  5. Fiberglass help!!
    By DirtySouthHtown in forum Fabrication
    Last Post: 08-01-2001, 01:35 PM
