Results 1 to 10 of 20
Thread: What to use to "glue" plexi glass or acrylic?
    Maximum Bitrate riddle14's Avatar
    Aug 2003
    TN
    What are some of the names of glues, epoxy, ..., that people are using to make their plexi glass or acrylic cases. I have asked this question several times, but when I go to find the product I never can. So maybe someone can tell me what and where to get it. I have used an epoxy before to put together some plexi, but after a while it got brittle and fell apart.
    "I'm going back to Cali(Iraq), Cali(Iraq), Cali(Iraq), I'm going back to Cali(Iraq), Cali(Iraq), Cali(Iraq), I know so!!!!" Now I'm here!!
    By "ToneRiddle"
    Maximum Bitrate sfay93's Avatar
    Feb 2004
    Omaha, NE
    I used this:
    Just hold the 2 pieces together and inject a little at the seam and it uses capillary action to move into the joint. Hold for like 10 seconds and it is done.
    Cost $2.99 at Hobby Lobby.
    ATVMS.com
    Aug 2003
    TN
    cool thanks, looks like i'm makin a trip to the hobby lobby tomm.
    By "ToneRiddle"
    Feb 2004
    Omaha, NE
    I found it back by the model cars and such. I put my case together and tested on some pieces and only used a little more than a 1/4 of the bottle.
    ATVMS.com
    FLAC samc's Avatar
    Feb 2003
    Brooklyn, NY
    its called Metholyene Chloride. Any acrylic shop should sell them, and I'm sure they come in brand names as above.
    Mine needs to be updated.
    Aug 2003
    TN
    thanks guys, went and got some this morning. tried it on some test pieces and worked out pretty good. i can see that the more coats you add the better. pretty strong bond though. i'll post some picts of my case once i'm done.
    By "ToneRiddle"
    Constant Bitrate e_z_street's Avatar
    Feb 2004
    This is what the "pros" use.
    Weld-On 3 or 4, depending on the thickness of the joints. It actually "welds" the acrylic together.
    You can buy it here or other places.
    http://www.tapplastics.com/shop/product.php?pid=131
    * I am not affiliated with any of these companies.
    Also, this has been covered many times before in this forum.
    Good Luck
    Maximum Bitrate jzgt's Avatar
    Mar 2002
    I like to use Devcon 5 minute epoxy. It works well, dries clear and is pretty damn strong. What I'll usually do is, use tape (like blue painters tape) to border the joint about an eigth of an inch, then epoxy, mate the two pieces, wait a minute (or less - use the left over from mixing to judge its state of chemical reaction - you don't want it too runny or too stiff) and remove the tape to take care of any over run (and to get a really nice seam). That's probably the longest pseudo sentence I've ever typed.
    - Jeff
    Low Bitrate Dr Jeckyl's Avatar
    Mar 2004
    Bakersfield, CA
    I like to use Duct Tape because it holds everything together. Has a nice finished alumi-chrome look to it too!
    Maximum Bitrate jusatry's Avatar
    Nov 2003
    Quote Originally Posted by Dr Jeckyl
    Duct Tape and WD 40 can fix anything! If it isnt moving and ist should be, WD40 it, if its moving and isnt supposed to be, tape it up!
  1. Gluing vinyl to acrylic
    By MP3DUB in forum General MP3Car Discussion
    Last Post: 10-27-2002, 01:28 AM
  2. Making new case lid out of plexi....
    By THEMP3KID in forum General Hardware Discussion
    Last Post: 04-22-2002, 12:25 PM
  3. acrylic case, anyone tried it?
    By Kajo in forum General Hardware Discussion
    Last Post: 04-17-2001, 10:04 PM
