Results 11 to 20 of 27
Thread: Fiberglass Sub Enclosure project
  1. #11
    Low Bitrate Dr Jeckyl's Avatar
    Mar 2004
    Bakersfield, CA
    7 layers is a lot! -- 3 or 4 layers has enough strength to park a car on.
    If at first you don't succeed, so much for skydiving!
  2. #12
    Quote Originally Posted by LittleDragon
    Did you lay anymore fiberglass over the resin'd fleece? I'm building boxes soon for my MR2 and I heard local shops use about 7 layers of fiberglass when making a sub box. I don't want the walls to flex too much as the sound quality would suffer greatly.
    It depends on the fiberglass you use.
    3-4 layers of 6oz FG would be enough for most sub boxes.
    Really high powered systems would suffer under a lot of pressure.
    I'm guessing you're putting 2 8" or 2 10" behind the seats.
    I put 2 10" subs in sealed boxes behind my seats and the amp in the front trunk, but I used MDF for most of it.
  3. #13
    Low Bitrate Deadnick's Avatar
    May 2004
    Duvall, WA
    Wow this thread inspired me. I think I'm going to run to the marine shop and hook up a gallon of fiberglass and some mat and go to town
  4. #14
    Registered User wyckyd's Avatar
    Mar 2004
    Tulsa, OK
    I don't know if it was overkill or not, but my friend and I used 3/4" of fiberglass on all sides of his enclosure for his 12" phoenix gold titanium...its what the stereo shop told us to do.
  5. #15
    Constant Bitrate coachreed's Avatar
    May 2004
    Lee's Summit, MO, USA
    Quote Originally Posted by wyckyd
    In my opinion, 3/4" thickness of FG is just a little overkill... that box definitely has to be solid though... how big of a box it is, and how much did it weigh when done? Though FG is light (relatively), a 3/4" thick box of FG gets kinda heavy.
    Later!
    Coach... aka Randy
  6. #16
    Registered User
    Feb 2004
    Updated - New Pics !
    Here's a quick update and some new pics...
    So here's a pic of the my car; '81 911 SC
    Here's an updated picture of the sub enclosure. It's working out really well however, I think I'm going to need to re-upholster with some better quality vinyl. The heat and sun is already changing the color.
    Fabrication of the mounting cover for my Lilliput LCD screen. Again made with fiberglass and bondo. The finish is an almost perfect match to the black interior. I used tremclad semi gloss paint and a few layers of clear coat. Worked well.
    Picture of it installed in the car. Basically, I removed the stereo, relocated the lighter, three ways, fogs and attached the lilliput and it's casing bolted from the rear without any modification or damage to the original dash coverings. Hard as hell to get it in but I got it!
    Night time view of it...
    I still have a few things to do to complete but it's almost there. Works great too! I'll keep posting updates.
    Shayne
  7. #17
    Dec 2003
    Minnesota
    That is very awesome! Great job!
    http://www.AJQuick.com/ - Fiberglassing Tutorials!
    My Cardomain Page - 1998 Dodge Neon R/T
  8. #18
    Low Bitrate TommieG's Avatar
    Mar 2004
    Norway
    congrats!
    That looks absolutely stunning....
    BTW. where did you put the PC?
    Tom
    VIA EPIA M9000/120 GB/Xenarc 700TSV/Opus 90W DC-DC
    Haicom GPS/3Com 11g Wi-Fi/D-Link BT
    WinXP/myHTPC/InfoMap Navigator Eu/PhoneControl w/T68i
    Blaupunkt HU & speakers/Velocity active subs/Alpine amps
    Progress: removed while waiting for nano-itx
  9. #19
    Variable Bitrate Batmanatthenewb's Avatar
    Sep 2003
    Newark, Ohio
    Look on the bright side.... if it was hard as hell to get in, it will be harder than hell for someone else to get out. Nice install.
    Batman
    Batman@TheNewBatcave.com
    AMD XP 2000, 1gig PC2700, 80gig 7200RPM HD, DVD CD/RW, ATI All in Wonder 8500DV w/remote, DataChute, IRDA, Wireless 802.11b, cell modem, Lilliput 7" VGA TS, XP Pro, GPS w/Routis
    www.samshomepage.net
    www.Cars-N-Computers.com
  10. #20
    Registered User
    Feb 2004
    Quote Originally Posted by TommieG
    Tom
    everything is under the drivers seat. There's not much clearance but I got it in. I'll try and get a pic when the wires are cleaned up.
    Shayne
  1. The Vectra CarPC / CarPuter Project v2
    By ccsnet in forum Show off your project
    Last Post: 08-29-2005, 06:46 PM
  2. Carputer as a comp sci final year project?
    By MikeHunt79 in forum General MP3Car Discussion
    Last Post: 06-23-2004, 10:19 AM
  3. Non-permanent fiberglass mount
    By Chairboy in forum General Hardware Discussion
    Last Post: 03-21-2004, 04:33 AM
  4. dvd external enclosure drive
    By kuo in forum General Hardware Discussion
    Last Post: 03-07-2004, 05:36 PM
  5. RLion Project Webpage
    By Reactor in forum General MP3Car Discussion
    Last Post: 02-18-2004, 06:43 AM
