Originally Posted by Kupop
One thing I would like to add, you need to take into consideration driver displacement and any other additional supports or items inside of the enclosure. If you have 1ft x 1ft x 1ft perfect cube, the volume is 1cu.ft.
Once you put in the subwoofer, the driver takes up some of that space, if you have any supports on the sides (not for this small, but a larger box should!) they take up space. So if a subwoofer calls for 1cu.ft of internal volume and that doesn't account for the driver displacement and supports, a 1x1x1 box will not be correct.
