Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 51
Thread: Sub enclosure volume Tip!!!
  1. #31
    Variable Bitrate Freeman's Avatar
    Aug 2003
    Australia
    eik a mouse.
    It aint no family car.
    SEE MK2 At : -
    http://www.mp3car.com/vbulletin/showthread.php?t=22810
  2. #32
    Variable Bitrate Banderon's Avatar
    Sep 2003
    NJ
    An Australian afraid of a mouse? You live with kangaroos! They're like super-giant mice!!
  3. #33
    Aug 2003
    Australia
    hahahahah, how could we be scared of kangaroos we ride them to work.
    SEE MK2 At : -
  4. #34
    FLAC Chairboy's Avatar
    Jan 2004
    Quote Originally Posted by Banderon
    With, if I understand the animated documentaries correctly, boxing gloves. They are shipped around the world in crates.
  5. #35
    Sep 2003
    NJ
    So how can you be scared of a mouse, aka, a mini-kangaroo?
  6. #36
    Mar 2004
    Quote Originally Posted by Kupop
    The packing peanuts sure. Water, sure... never heard of anyone using tea or coco mix to figure out how much water though.
    If you fill with it liquid you could just measure the difference in weight then do some simple math, figure out how much weight of liquid (water most likely) is in it, then do more math to convert it to volume.
    You could also remove the water out of the enclosure and then measure it in measuring cups or something.
    w/ this method you have to know temperature of the water and the pressure on the water... then from that you figure out the density...
    note: to get an accurate reading from the thermometer... read the bottom of the meniscus...
    you can figure out the pressure on the water by finding out what your elevation relitive to sea level... or you can use a barometer
    also... use spring water... don't use tap or sea... b/c they have minerals and salt which won't allow you to get an accurate density if you look it up in your
    after that... go into your thermal dynamics book or fluid mechanics book and look in the water properties table, find the coresponding density
    take the inverse of the density and multiply by the mass of the water and there you go... you get the volume.... its that simple
  7. #37
    Aug 2003
    Australia
    saint thats to much to think about
    SEE MK2 At : -
  8. #38
    Aug 2003
    Australia
    Talking
    JUST MAKE A BLOODY BOX WITH RIGHT ANGLES and u cant go worng
    SEE MK2 At : -
  9. #39
    FLAC john1701's Avatar
    Mar 2004
    Fort Myers, Fl
    what about beer? just count how many cans, tada!
    CAR:2001 Ford Crown Victoria
    PC: Acer EEE 900HA with Win7 with CF 2.0.
    Memory:1G
    Drives:160gig
    WI-FI:Cingular
    GPS:IG2k9
    Screen:Xenarc 700TSV
    The Florida Meets Thread
  10. #40
    Aug 2003
    Australia
    finally someone with an educated solution
    SEE MK2 At : -
  1. MP3 Volume Normalization
    By eCarô in forum General MP3Car Discussion
    Last Post: 01-12-2005, 12:09 PM
  2. Replies: 11
    Last Post: 02-11-2004, 10:59 AM
  3. Replies: 6
    Last Post: 11-12-2003, 09:57 PM
  4. USB Sound Card with ASIO driver and volume control
    By tbdombrosky in forum General Hardware Discussion
    Last Post: 02-03-2003, 11:00 PM
  5. The volume question: MASTER vs. WAVE
    By tbdombrosky in forum Software & Software Development
    Last Post: 07-19-2002, 02:59 AM
