Page 1 of 4 1234 LastLast
Results 1 to 10 of 35
Thread: First attempt at fiberglass
    As the title suggests im a fiberglass virgin.
    Im from Melbourne, AUS and had to do some hunting around to find the materials I needed much less some ppl round here that do it all the time and know their ****. In the end I found the materials at the local bunnings, but to say I thought the prices were hi is nothing! So where to melb pplz find their bits n pieces or AUS in general.
    Well after buying the very expensive stuffs, I went to task doing my first layer of glass. I reckon I used just about all my 300grams of resin on this layer. Now did I go over board with the resin or what? And how long does on layer take to dry? Do you apply a second layer to the wet first layer of after is dried? AND *takes breath* can I speed up drying at all, its a **** old day here and cold and damp as a *****. I happen to have one of those mobile sun kinda lamps sitting round the place could I employ that to speed up drying?
    To giva ya an idea of the area im covering here a pretty ****ty pic
    Low Bitrate Dr Jeckyl's Avatar
    Mar 2004
    Bakersfield, CA
    you might have used a little too much on the first coat. The first coat can be thinner so it dries faster. Then you can remove it and make your next coats as thick as you want.
    It needs to be dry before you remove it. I don't know about sun lamps, but fans work pretty good. More air circulation will speed up drying.
    Registered User
    Feb 2004
    I found the warmer the better... I've done a few jobs in the garage in let it sit overnight on a cold night and the next morning still not fully dry. A fan and a little space heater helped and dried it right up within a half hour.
    In the sun though, it dries really fast... the last sub enclosure which I finished last weekend, I ended up doing most of it outside in the sunny weather... the left side would dry by the time I finished the right side.
    Also, a good little trick to speed up drying, I found was to double up on the hardener. I mixed 25 drops to every 1-once. Be careful not to add to much hardener, as the mix will gel up.
    I end up always doing 2 coats before removing the mold. The first coat just seems to be to thin and the mold looses its shape. For larger molds, I add extra support with wooden dowels which help retain the shape.
    Variable Bitrate Freeman's Avatar
    Aug 2003
    Australia
    thats not a cortina is it?
    It aint no family car.
    SEE MK2 At : -
    http://www.mp3car.com/vbulletin/showthread.php?t=22810
    Variable Bitrate Banderon's Avatar
    Sep 2003
    NJ
    You should use 2 coats to be safe. Go easy on the first one; let it dry quickly. You can go a little thicker on the second one, to reinforce the structure.
    Thanks guys, yeah I thought that going through one of the 300 gram cans of goo might have been a bit much for a single area that small. I'll chuck a fan in there an see how we go. I'll keep yall updated.
    Freeman: nup its an XE falcon with a 351 5.8tl V8. u can chek it out at
    http://www.cardomain.com/id/gandog
    Sep 2003
    NJ
    Anyway, that's how we learn. Try and see how things work out, and then learn from any mistakes made.
    Top Ramen lgbr's Avatar
    Feb 2004
    Spokane, WA, US
    That picture answered a question I've been wanting to know for a long time. The accelerator IS on the right side in British cars, my god.
    Audio Rockford Fosgate: 900 Watt 4-channel amp, 501bd Mono amp
    Computer AMD 2400+ XP, 1 GB DDR RAM, Orbit Micro 250W DC-DC PSU
    Head units are for cheaters!
    sure some girls fake orgasms.....but it's guys like me who fake the whole relationship
    Or Australian even
    I've put a fan in there and it seems to be doing the trick. The way Ive done it it seems to be a coont to get to in some places reckon theres any harm in taking it out after the 1st coat is hard and putting the second coat on outside the car?
    Sep 2003
    NJ
    Well with the thickness of your 1st coat... I guess you could give it a go.
  1. Fiberglass Sub Enclosure project
    By shillier in forum Fabrication
    Last Post: 02-06-2009, 04:30 PM
  2. Before putting fiberglass in trunk for sub box...
    By Seabass in forum General Hardware Discussion
    Last Post: 10-08-2006, 02:30 PM
  3. fiberglass or bondo??
    By faiz_23 in forum Fabrication
    Last Post: 05-04-2004, 07:39 AM
  4. Non-permanent fiberglass mount
    By Chairboy in forum General Hardware Discussion
    Last Post: 03-21-2004, 04:33 AM
  5. fiberglass how-to videos?
    By etrik in forum General MP3Car Discussion
    Last Post: 02-08-2003, 01:24 PM
