Results 1 to 10 of 16
Thread: Laquer?
    May 2003
    UK
    Laquer?
    So i've almost finished my MDF/Plastic/bondo custom dash - Now i need to think about paint,
    I can use some standard black spray paint ( dash is a smooth matt black ) normally I would lacquer this - can you get a matt lacquer? - or any other suggestions for protecting it?
    www.digital-car.co.uk - The UK CarPC Forum
    Oct 2003
    DC/VA
    Being that you are working with plastic and bonda I would suggest to you a paint made for plastics. I personally use SEM vinyl spray paint that you can pick up from an automotive parts store. Then depending on the finish you want you could wet sand it.
    May 2003
    UK
    how durable is this finish?
    James
    Oct 2003
    Toronto, Canada
    Hmm, is it possible to give it a 'CF' look? Perhaps some tape or something? Anyone know?
    Edit:
    I found CF tape, but that wouldnt cover the area or give it the looks. Hmmm.
    VIA Epia II
    256MB 266DDR Ram
    90GB Wester Digital
    Bluetooth/Deluo GPS
    Lilliput 7" Touchscreen
    Mazda 6 Carputter > Click Me!
    Wisconsin
    I too am interested if theres any sheets of CF that you could use....
    May 2003
    UK
    i've definatly seen large CF panels - try a bit of googling
    FLAC djmickyg's Avatar
    Feb 2004
    u can get a matt lacquer..
    what sorta paint are u using??
    if its an enamle.. like a 2pac car paint paint.. generaly they are pretty strong and dont really need a lacqure.. the finish is off the gun...
    if u go for an acrylic u will have to laqure it.
    look for car paints.. there alot tougher
    May 2003
    UK
    ended up spraying it with a black "satin" spray paint, came up perfect - and matches other dash panels well, no need to lacquer the finish seems very durable..
    James
    Constant Bitrate meissenation's Avatar
    Macomb, Michigan
    There are CF twill that you can buy on ebay for about $20. I bought the sheet, it looks really good, I think it just needs a layer of resin over it to give it the finished look. I've never fiberglassed before, but I guess it's meant to take the place of the fiberglass sheets.
    CarPC v3 - 6/4/2008 - Project Showoff Thread
    CarPC v2 - Project Showoff Thread
    Michigan FBody Association - Administrator and Owner
    Maximum Bitrate brrman's Avatar
    Aug 2003
    Indianapolis, IN USA
    I used "satin" paint. But I wish I had used vinyl dye (SEMS, etc) because the finish would be much more durable.
    Car: 2000 Audi A4 Avant 1.8t
    Carputer 2.0: removed. Back to stock.
